Old 11-30-2007, 01:23 PM
ccracin's Avatar
ccracin ccracin is offline
Sweet makes very nice stuff. I used their stuff in my Late Model. Check the 22" dimension. When I talked to them about our project they wouldn't go that wide. That was about 1 1/2 years ago. I can't remember for sure.
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 11-30-2007, 05:24 PM
68protouring454's Avatar
maybe its 21, but i did check with them as i was looking for a 22 inch pivot rack last spring and thats as wide as they liked to go
Jake's Rod Shop
Old 11-30-2007, 05:38 PM
ironworks's Avatar
Then a sweet rack would not have worked on this car any ways.
Rodger
Old 12-11-2007, 09:01 AM
Impala TT Impala TT is offline
Rodger,
We were wondering what track width you went with on the Nova? We are struggling finding a power rack with a 22.5" pivot. We're trying to run stock Camaro track width so we don't have a front wheel drive looking wheel! Any insight would be appreciated.
Thanks,
Brent
Old 12-11-2007, 09:38 AM
Originally Posted by Impala TT
Rodger,
Thanks,
Brent
there are two track widths that are talked about, hub to hub, and wheel track, hub to hub is what most chassis builders use when talking, so even if a stock camaro is 59 inch hub to hub and you build a new chassis 6.15 or whatever, you go deeper on the bs on the wheel which maintains wheel track width, yet in most cases gives you better scrub radius, among other things
Jake's Rod Shop
Old 12-29-2007, 11:33 PM
novanutcase's Avatar
novanutcase novanutcase is offline
Default My Camera Sucks!
Took a couple pictures of the car on the ground but they aren't very good! I'll try and get Rodger to snap a couple off!
John
Old 12-30-2007, 06:49 AM
Ricochet's Avatar
Ricochet Ricochet is offline
That thing just sits sinister!! Bad ass John! Much like everybody else, I have been watching this build for sometime - it's getting close!
Brent
