Go Back   Lateral-g Forums > Technical Discussions > Trucks
Old 12-04-2007, 06:06 AM
awr68's Avatar
awr68 awr68 is offline
Looks real good Chris!! What's that blue thing in the background?
Tony
'68 Camaro
Old 12-04-2007, 04:58 PM
awr68's Avatar
Originally Posted by race-rodz
thats a project i should have been workin on instead of this, the owner is a pretty kewl guy, very understanding
Tony
'68 Camaro
Old 12-23-2007, 06:49 AM
dave96dcm dave96dcm is offline
I really like the way that you made the pivot for the Watts link, did you have to add a crossmember near the frame mounting points to keep them from trying to seperate or pull together when cornering hard? Is that a delrin bushing on the center pivot? I need to add a Watts to my 1996 Impala SS and I really like this idea vs puting the pivot point on a crossmember.
Old 12-26-2007, 06:11 AM
Ok, that makes sence. Is it a Ball bearing or a needle bearing? Is that just a 3/4" bolt on the pivot that is tacked in place so you don't have to hold it with a wrench while tightening the nyloc nut? Thanks for sharing your secrets
Old 12-26-2007, 10:18 AM
Thanks for your help.
