Old 12-11-2007, 10:15 AM
Not much room up there on a 67-68 due to the curvature of the quarter panel.But it would be beneficial on say a 69.
Old 12-11-2007, 10:58 AM
AllSpeedAndy AllSpeedAndy is offline
You can see what i did for clearance...and instead of welding to the quarter, if body work is already done. You can use a metal bond the is avail. at any finish master or body supply store.
Old 12-11-2007, 11:56 AM
Mrfixit Mrfixit is offline
That's a tough picture to figure out. It looks to me like the outer wheelwell ceiling was raised using two strips of metal. Is that right?
Old 12-11-2007, 12:30 PM
What I did was, cut the outer radius off the outer house....
The middle of the outer house is still in tact...
At the top center, just before the house starts the bend tward the quarter
I cut there, from the front to the back....then I cut the lip 1/4" back from
outside of quarter, that not only cleans up the lip but cuts the factory spot welds free. Once the old stuff is out I took some thick construction paper and made a template...once that fit good then I made it out of metal.
I've got some better pics of the mod I'll have to post tomarrow...
that was the best pic I had on hand...sorry
The middle seem is were the DSE tub meets the out house.
Old 12-11-2007, 12:39 PM
AllSpeedAndy - OK. I think I understand it now. It sounds very much like what I was planning. Still, I would appreciate any more picture that you may have including some from above in the trunk and seat compartment.
Thanks again..
