Old 12-13-2007, 05:14 AM
Default LS1 PCM Pinouts
Here are the PCM pinouts for my 2002 LS1 PCM from a vette. 2 connectors with 80 slots each - but many aren't used.
I don't have a harness yet - so I left the gauge column open for later. I asterisked the items I felt should be in the bulkhead connectors. Looks like we could easily get 2 bulkhead connectors with enough capacity - even if we break them into power/servo and sensor.
Jim
Old 12-13-2007, 05:42 AM
HWYSTR455's Avatar
HWYSTR455 HWYSTR455 is offline
Excellent! Ok, I think if one or two bulkhead connectors were identified and a source for them, all could use them as they choose. Maybe three would be the way to go, since some may want to use only one total bulkhead for all the leads. I think a 48-pin for a total would work, but would have to look again to be sure.
I looked at some of the connectors yesterday, there were ones that were waterproof, and oil/fuel proof that had enough pins.
1971 Lemans Sport 461 bottle fed daily driver
1971 Trans Am 474 blown EFI pro tour car
1972 442 W-30 clone
Old 12-19-2007, 08:23 PM
V8TV's Avatar
V8TV V8TV is offline
How about these weatherpack bulkheads?
http://rjminjectiontech.com/?p=12
Kevin Oeste
V8 Speed and Resto Shop
V8TV
Muscle Car Of The Week
V8 Radio Podcast
All about us:
https://www.v8speedshop.com
Old 12-19-2007, 09:28 PM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
I like this one, but is enough pins?
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
Old 12-20-2007, 04:19 AM
HWYSTR455's Avatar
Nope, would probably have to do 3 of them, and don't think they're RF insulated within the connector....
1972 442 W-30 clone
Old 12-20-2007, 05:01 AM
dhutton dhutton is offline
OK, why do you need RF shielding within the connector if all the rest of the cable in the harness is not RF shielded? I don't think this is necessary and it doesn't gain you anything.
Old 12-20-2007, 05:46 AM
HWYSTR455's Avatar
Some do have shielding, and there's also a dependance on the resistance of the conductor as well. I don't recall off the top of my head which, but once I revisit this area I can post. I just kept a mental note that it was required, though it's possible I could be wrong on that. Certainly two I know of are crank & cam sensors. Guess that might be only an issue if you mount the CD box inside...
1972 442 W-30 clone
