Old 02-01-2008, 12:07 PM
Musclerodz's Avatar
Default Posi or Tru-Trac?
Who has used both and which did you prefer? I can't stand to leave the 2.56 open in the convertible, so the parts are going in a box to save and a more respectable gear set is going in.
Mike Redpath
Musclerodz & Customz
facebook page
Old 02-01-2008, 12:39 PM
Payton King's Avatar
Default I have had both and I can tell you the
tru-track is smooth as silk. I give it 2 thumbs up!
Old 02-01-2008, 04:20 PM
NovaBlue71's Avatar
NovaBlue71 NovaBlue71 is offline
I second that. We put a tru-trac in Paul's chevy II and it's smooth as silk too. Joe
Old 02-02-2008, 08:49 AM
We are nearing 100 happy Tru track buyers. Just picked up 4 more Tuesday. No other choice
Frank Serafine
Old 02-02-2008, 06:01 PM
blown71nova blown71nova is offline
Switched over to Tru-Trac in both of our Muscle Cars!!!!!
Old 02-02-2008, 09:51 PM
Musclerodz's Avatar
Well I guess that settles it. I had pretty much made up my mind to run a Tru-Trac, but this just confirms it. Thanks guys.
Mike
Mike Redpath
facebook page
Old 02-03-2008, 06:41 PM
mazspeed's Avatar
mazspeed mazspeed is offline
Had both and the tru-trac blows it away.
Old 02-04-2008, 10:48 AM
First post I think but long time lurker :-).
Anyone think it would be possible to convince Eaton to build a 35spline trutrac? There is always a lot of interest in a stronger 9" unit. I think all they have is 31spline. It would be nice to have a 35spline unit so it would be feasible to have 2 centers that could be swapped out without having to swap axles too. You could have 1 trutrac and 1 spool both 35 splines. Right now I'm leaning towards 12 bolt with 33 spline trutrac but I'm afraid it just won't last if I go to the track.
John
Old 02-04-2008, 01:30 PM
Blown353 Blown353 is offline
John
The 33 spline 9" axles will probably be fine... if you buy good axles. (Mark Williams-- Period. The 300M axles are really tough.)
And I would not do a 33 spline 12-bolt... The axle diameter is getting to be so large the carrier diameter under the carrier bearings starts to get thin and you now have a new failure point.
1969 Chevelle
