Old 02-05-2008, 01:59 PM
LDB LDB is offline
Default 2" or 3" rear drop leafs?
Is there really any difference in the two. Pro's and Con's? If anyone has pictures of there 67 camaro with 2" or 3" rear drop leafs please share. I will be doing one or the other just wanting to know any set backs. Does it affect the ride quality? Thanks again.
Old 02-05-2008, 04:30 PM
67ragtp 67ragtp is offline
Heres mine with dse 3 inch drop leafs and I wish it was 4. 17" wheels. No issue with ride quality, just avoid big bumps. Go 3" if you must use leafs. My issue with it is the rear ride height is not adjustable- next time 4 link.
Rich
Old 02-05-2008, 08:13 PM
mdprovee's Avatar
mdprovee mdprovee is offline
I bought the 2"...will be dearching the springs or something to lower it more. Start with the 3" ones.
Mike
Old 02-05-2008, 08:22 PM
awr68's Avatar
awr68 awr68 is offline
Nice ride Rich!!
Tony
'68 Camaro
Old 02-05-2008, 10:10 PM
KPC67's Avatar
KPC67 KPC67 is offline
I agree with Rich, go with three inch.
And yeah Rich I too think your car is awesome!
Old 02-05-2008, 11:48 PM
If 3" isnt enough with leafs is it big no-no to shim it down a little with lowering blocks ? Like 1/2 - 1 " ??
63 Z06
Old 02-06-2008, 03:56 AM
Thanks Guys
Exhaust clearance starts getting a little tight underneath and I didnt want to push it, so I decided to forego the lowering blocks. Theres also a fine line between having the car slammed to the ground and ripping out your headers or somethong else if you drive it and hit a raised man hole cover or bump. Good luck
Rich
Old 02-06-2008, 10:34 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Send SteveO a PM. He gave me a really good run down on all this and I know he would do the same for you.
Curtis
