Old 02-10-2008, 02:01 PM
Hi Travis !
Thought I would jump in. I have a Pro-Tools bender (HMP200C) and I can do a basic roll bar with no problem. Mine was $640 plus 67.00 in shipping. You do need to pump the handle - but I can bend 110 degrees easily in thickness up to 1/4 inch wall. I have a 6 inch die - but they carry all the way down to 4 in if you wanna go that tight.
Check my build section where I posted pics @ https://lateral-g.net/forums/show...t=5109&page=10
I'd highly recommend a digital level (mine is a SmartTool version) and get the how to bend tubing from Mittler Brothers. In their video they specifically walk through how to measure, setup, bend and check a 4 point roll bar. They provide the math formulas, radius charts and even give a real world way of doing the project with very little math. I watched the video a couple times taking notes, put together my measurements, plugged them into the formulas and nailed it. I found it VERY helpful as I'd never bent anything bigger then brake/fuel lines.
Another option is to do a paper template with measurements - and send those to someone. I used one of our sponsors here Ironworks Speed and Kustom for the hoops I needed that I couldn't bend - and they built what I needed and got them back to me. See page 14 of my build and you'll see those driveshaft hoops.
Good luck and remember - YOU CAN DO IT !!
Jim
PS, you will want to get the mittler brothers tube clamp for the SmartLevel too - man I CAN'T live without that assy !
Old 02-10-2008, 05:25 PM
Travis77's Avatar
Travis77 Travis77 is offline
Thanks so much for the info.. Sounds like good advice to follow if I decide to do it myself.
Old 04-30-2012, 07:37 PM
Hotrod1's Avatar
Hotrod1 Hotrod1 is offline
I built this one and it is fantastic. Have done a cage and it works beautiful.
http://gottrikes.com/Tube_Bender.htm
Old 06-08-2012, 08:12 AM
tn10.5guy tn10.5guy is offline
lots of good info here. I like the shark bench w/ both the bender and notcher together, but thats a pretty steep price for a diy/ hobby person to take on. I will prob buy the jd2 model 32 hyd. I already have a air/hyd unit from work i can put with it and a stand should be easy enough to build but not sure of material cost (or if I can build it for 135.00 there price). I already have a small notcher and welders so my next purchase will be a bender. Thanx guys for all the info and insight
