Old 02-12-2008, 04:15 PM
Marcus SC&C's Avatar
Klaus and I have been working this over and the primary issue is that the car is simply set much too low. He raised the ride height some and the arms had a lot more clearance. At this point the pivot axis of the lower ball joints was still above the inner pivot axis where the arms bolt to the frame. That`s too low. You want the inner pivot far enough above that you allow for some brake dive before the geometry goes south. See pic. The orange line is level. The red line shows where a line between the pivot axis is now (at the "raised ride height") and the blue shows where it really should be for best geometry and performance. Basically the Spohn arms use the cross bar in lieu of a bumpstop to prevent over compressing the suspension and causing shock or steering linkage damage.
At that height the car is still about 1.5" or so lower than stock and everything has plenty of clearance and travel. If you want the car lower for cosmetic reasons simply use tall lower ball joints (in this application) or spindles with some additional drop like AFXs and you can have lots of travel,great geometry and the stance you want. Coil overs aren`t the end all be all of lowering a car and making it handle,they`re just another useful tool in the box. Like any tool they have to be used properly for best performance. A new option BTW are the SPC Performance tubular lower arms which offer 1" of additional drop and more clearance as well as enhanced geometry and bumpstops. We`ll have them up on the site as soon as our web guy gets off his butt. Mark SC&C
Old 04-10-2008, 11:34 PM
el-camino's Avatar
el-camino el-camino is offline
yesterday i have my first rollout after the wintertime
the bad news first.
the car is undriveably.
why ?
the car is now 2.5 inch lower than before with the Hotchkis springs.
steering is the biggest problem, you cant turn from left to right.
the car is definitive to low.
i think this are 7" long varisprings, will i helps when i replace this with 9" ?
and last but not least, the biggest joke are the lower tubular a arms from spohn.
this a-arms have no steering stop limit and no bump stops.
the centering for the ball joints is not the same as on stock arms.
and this will say, i come with the steering parts more backwards.
i think i replace the lower arms and buy the g-plus from global west.
the global west have all the features, bump stops, steering stops.
greets
klaus
greets from Sweden
Klaus
Old 04-26-2008, 03:40 AM
el-camino's Avatar
yea, its done.
the problem is solved.
yesterday arrive my new lower tubular a-arms from Global west.
i replace the spohn arms with the global west arms, and ??
yeep, the car looks for the moment as a bigfoot on the front !
i only change the lower arms and this raise the front 2.5" !
the geometry is much more better than before.
that says to me: the spohn arms will not work on my car and the upper arms.
pics follows today.
when you have the two brands on the table, you can see the difference.
greets from Sweden
Klaus
Old 04-28-2008, 01:25 AM
el-camino's Avatar
here are now two new pics.
the first pic on the left side the spohn and right the global west.
the global west comes with bump stops and steering limiter and stabi-rods, the spohn has nothing.
with the spohn you have no place between chassis and a-arm.
on the second pic you can see on passenger side the global west and on drivers side the spohn. both sides the coil over fully compressed.
forget the spohn for the g-body
i will post today new pics when the car is on the ground
greets from Sweden
Klaus
Old 04-28-2008, 05:39 AM
el-camino's Avatar
aah, i forget to say:
the tool for the varishocks is a big joke.
busted knuckles guaranted
greets from Sweden
Klaus
Old 05-01-2008, 08:32 PM
Blake Foster's Avatar
the tool is not the problem, everyone forgets or is not told about the adjuster bearings that are available for the coilover conversions, they are a MUST!
Blake Foster
www.speedtechperformance.com
Old 05-01-2008, 10:40 PM
el-camino's Avatar
adjuster bearings ?
thanks killer69, no one tell me about this stuff
greets from Sweden
Klaus
Old 05-06-2008, 12:28 PM
Just goes to show different things work for different folks. We have an `87 GN in the shop right now with exactly the same Spohn lower arms, coil overs and 2" drop spindles and we have it sitting at near stock ride height. I`m glad you have the car where you want it now though.
BTW if you think the Varishock spanner with the 4 huge teeth is a knuckle buster you`ve never worked with the standard 1 little tooth coil over spanners! The Varishock wrenches are really awesome in comparison.
Don`t count on the tiny GW bumpstops,the coilovers will still overtravel and the tie rods will still hit the frame before the bumpstops contact the frame. They`re just for looks. Check your compression travel and replace them with taller ones that will prevent over compressing the coil overs and you`ll increase the life of the shocks and suspension parts. Mark SC&C
Old 07-23-2008, 12:20 AM
el-camino's Avatar
back again and the problems are flying away.
the lower spohn arms are the problem.
they dont will work with my upper global west negative roll a-arms.
i install the new lower global west a-arms and this stuff fits great.
i drive now the last weeks without any problem
greets from Sweden
Klaus
Old 07-23-2008, 03:35 AM
Default Looks Good
El Camino car looks great now. I like the color and the stance.
Wayne
