Old 03-16-2008, 08:21 AM
BBShark BBShark is offline
Default Porting Burr Source
I am porting an aluminum manifold (first time). I see lots of individual burrs and porting sets. Anything I should look for? Can anyone recommend a source?
Old 03-17-2008, 06:49 PM
Nate_ERC's Avatar
Nate_ERC Nate_ERC is offline
Get a job grinding castings I worked at a large titanium foundry out of highschool, and I pilfered literally thousands of resharpened carbides. We used to just toss them because only the new ones will cut Ti.
Sorry I know that doesn't help, but I also would like to know if anyone has a preferred source for stones, flappers, burrs, etc...
-Edit-
Oh by the way, make sure you use some cutting lubricant when using aggressive burrs on Aluminum or it will clog the flutes and make them worthless in no time.
www.eckertsrodandcustom.com
Old 03-18-2008, 06:38 AM
-Edit-
That brings back memories, I used to have a job deburring SS, Monel and Inconel industrial valves for a while. It sucked. I was constantly pulling metal slivers out of my arm and hands.
I also have some carbide burrs but they load up (as you described) with soft material. I guess that's my real question. I see they are available for ferrous and non ferrous materials but can't find the difference.
Old 03-18-2008, 08:30 AM
DB Z28 DB Z28 is offline
I get mine from C.C Speciality Tool in Lawrenceburg ,Tennessee. Or Mondello out of Paso Robles ,Ca
Old 03-18-2008, 09:52 PM
Nate_ERC's Avatar
Fortunately Ti is like aluminum, and doesn't sliver like steel. I swear I'd quit using steel for anything if it wasn't so damn easy to weld.
Seriously though I don't know what the difference in the burrs you described would be; but if you use some kerosene to lubricate your burrs when cutting aluminum it really helps keep them clean.
