Old 04-16-2008, 02:12 PM
DDY RCKT's Avatar
DDY RCKT DDY RCKT is offline
Originally Posted by ProTouring442 View Post
What rear suspension are you planning on using?
Shiny Side Up!
Bill
Let me get it out of the truck and under the car, and I'll see if you can identify it.
2002 Corvette Z06
Old 04-16-2008, 05:32 PM
DDY RCKT's Avatar
Out with the old!
And in with the new!
2002 Corvette Z06
Old 04-16-2008, 05:36 PM
DDY RCKT's Avatar
There are, of course, some clearance issues to be corrected. Some trimming and integrating of the new subframe with the original frame. Still not decided if I'm going to make concessions to bolt the rear in and out, or weld it in. I'm leaning towards welding, but that's going to depend on how accessable it makes things like the sway bar once it's all in the right place.
Plenty a wide wheel should fit under the fenders, methinks!
2002 Corvette Z06
Old 04-16-2008, 06:34 PM
ProTouring442's Avatar
BMW?
I was thinking of using a Mustang or Thunderbird/MKVIII unit, but went Ford 9" instead.
Shiny Side Up!
Bill
You ever wonder what medieval cook looked at the guts of a pig and thought, "I bet if you washed out that poop tube, you could stuff it with meat and eat it."
Old 04-16-2008, 06:39 PM
DDY RCKT's Avatar
You know, guys, it's ok to talk to me about my project. I see you looking.
Anyone figured out what the rear suspension is from? You get a gold star if you get it right!
2002 Corvette Z06
Old 04-16-2008, 06:41 PM
DDY RCKT's Avatar
BMW?
Shiny Side Up!
Bill
Nope! It's much more appropriate than a BMW!
2002 Corvette Z06
Old 04-16-2008, 06:54 PM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
Why I believe that's also a GTO unit. 04-06.
Jim
Old 04-16-2008, 06:57 PM
DDY RCKT's Avatar
We have a winner!
It's a 2005 LS2 GTO rear indepentent carrier, with all the included bits and pieces. One crushed brake line, but otherwise nearly perfect. Rotor to rotor, it's the extact length of the original, maybe 1.4" off.
2002 Corvette Z06
Old 04-16-2008, 07:00 PM
Ummgawa's Avatar
I'd be very interested in the install of the IRS in the LeMans. Keep lots of pix coming, and, I'll be watching your build closely. I am building a 70 gto vert (the one the ahole ex friend of mine stole the front end from) and like the looks of the install. Very Cool!
Jim
Old 04-16-2008, 07:11 PM
DDY RCKT's Avatar
Thanks! It looks like it'll fit nicely. The spring perches are in the approximate location of the originals, as are the shock mounts, though the springs are shorter and the shocks are taller. I did, however, get the original upper perches that I can probably weld in to gain some of the height difference back. Either that, or it's going to squat right nicely.
I will probably end up getting some adjustable coilovers, though. That should help balance the system out somewhat.
2002 Corvette Z06
