Old 04-24-2008, 05:41 AM
PT Goat's Avatar
PT Goat PT Goat is offline
I'll do some math and measuring on the 275s.
But as long as I am running a larger wheel in the rear, I'm going to be looking at less sidewall, right? Unless I make it up in tire height, which probably means going wider to stay with the tire I want (F1 GS-D3).
No wonder it's taken me so long to order.
How about a 225/50/17 (25.9" tall) front and the 255/45/18 (27.1" tall) rear? That would be a 4.4" front sidewall and a 4.5" rear. Sound better?
Matt
1965 Pontiac GTO - Paul Spotts 421 (433) w/Tripower, RamAir, 6X Heads / TKO600 / 3.90 Safe-T-Track / Vintage AC / Baer 4-wheel Discs / AGR PS / Hotchkis Bars, Shocks, Springs / SPC & BMR Control Arms / 17&18 Intro Vistas / GY F1GSD3 Redlines / '06 GTO Seats / Comp Audio
Other Rides: '59 Vette / '64 GTO (x2) / '65 GTO / '66 GTO / '66 Vette Roadster / '02 Vette / '07 Avalanche LTZ 6.0L / '08 Suzuki GSX-R750
Old 04-24-2008, 06:15 AM
LCAC_Man LCAC_Man is offline
Finding tire sizes that work for you, and a tire mfr/model that cover both front and rear sizes is truely a PITA.
The sizes you mention above would work well together, same size sidewall and slightly larger diameter rear. A-Bodies are deceivingly large cars, 27" rear is as small as I would go. My last car was a Buick GS400, I ran a 28"+ 275/55/17 tire on the rear (after installing a smaller tire and not liking it) and it was perfect.
In the end you may have to go to a shop and have a couple different sizes installed and see just what makes you happy.
Len
67 Camaro SS350 Convertible
406/200r4
Len's PT Garage
Old 04-26-2008, 07:05 AM
PT Goat's Avatar
Thanks again for the advice. I am going to order custom redlines, so unfortunately, I'm not going to be able to do any trial fitting first.
Right now I'm leaning towards the 225/50/17 and 255/45/18 in the GY F1 GS-D3. I will search for a taller rear tire, but I haven't found any matches yet in a performance tire, at least not with GY or BFG.
Matt
Old 04-27-2008, 06:16 PM
Not trying to push you one way or the other but an option to get you to taller tires would be:
225/55/17 front
255/55/18 rear
Nice rake, period look in sidewall height, would really fill the wheel wells.
Len
406/200r4
Len's PT Garage
