JoeTouring.. I like it.. I notice a few of you guys are in DFW. I am about two hrs east. We have a company here that powdercoats frames for about 300 bucks.
I am definately one of the JoeTouring guys... Big dreams, little budget.
65 Malibu "Liberator"
91 Fox Coupe SSP "Emma"
Two phone calls today. One was from the machine shop the other from the plater.
Since I am using LS1 F-body rear brakes on a stock 72 rear there is nothing to hold in the factory bolt in axles tight. I had these spacers made to take care of that. I also had them cut down the front hubs to clear the C6 Corvette front rotors. the last thing I had them do was cut the stud holes to .503 to get the correct interference fit with my aftermarket ARP metric studs. I cut them down to 2.200 so they will still be long but stay under the closed end lug nuts.
The plating I am extreemly happy with. I had old greasy rusty original parts and new gold cad after market parts parts. I did not like the look of either. Anything that did not go to the powder coater went to the plater. After this I don't think I will ever clean a rusty bolt again. Below is just some of the stuff.
I got some high heat primer and Fusicks gold on the motor tonight. I should have waited till a daytime I could do it. The bugs and trash were getting in it like crazy. The intake and block still look great because the rough cast iron hides the imperfections. The pan and valve cover don't look to good up close. I will probably redo the valve covers since they are so visible.
