Closed Thread
Old 05-07-2008, 03:08 PM
skatinjay27's Avatar
sweet!!! i bet that feels like a BIG mile marker getting that engine in there!
that big block looks at home in there.
AJ
Old 05-10-2008, 03:56 PM
DOOM's Avatar
DOOM DOOM is offline
Hey Todd
Thanx again for letting me come over and see the Camaro I see the engine is in! Not much longer, I hope before its ready to fire!!!!! Thanx again!
Mario
Old 05-10-2008, 06:43 PM
Tranny is in...what a mother ***** ****** **** I am so wore out I don't fee like going into detail. Later
Old 05-10-2008, 09:46 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
At least it's in...and fits.
Curtis
Old 05-10-2008, 10:54 PM
monza's Avatar
monza monza is offline
Just went from the first post until now......
your car is really Badass! Can't wait to see it done and your close~NICE!
Dave
FUeL 69 Camaro RS
68 Corvair coupe
65 Impala SS
65 Corvair convert
64 Corvair Rampside
62 Corvair Greenbrier
http://www.sourceboards.com/
Old 05-11-2008, 09:05 AM
Appreciate it...it has a March ultra drive system on it. I have a new bracket being made as we speak that will look similar to the paper mock up on the motor.
After spending a couple hours centering the bellhousing, I figured it would slide right in. Ya right. We could get it within about a half an inch and it would stop. Figured it had to be clutch alignment problem so I took it back apart and got it as close as humaly possible with the same outcome. I got to thinking about when I mocked up the bellhousing on the tranny on the table. It was a very snug fit. In fact it took a little effort to get it on there. We figured out it was the hub on the tranny not wanting to seat in the bellhousing. Since I only had a **** hair for the clutch to be off, I used a tie strap and cranked the clutch fork all the way back to let the pressure off the clutch then it would move with the tranny. Then we were able to get it in all but 3/16 to 1/4. We knew at that point the clutch was engaged and so was the pilot bearing mostly. So I sucked it in slowly with the bolts which is usually the wrong idea but I had no choice. A little resistance then it slid right in. Everthing feel right and turns freely. The photos are of it jacked up until the vent almost touches the floor. Looks damn close to stock crossmember height. I am going to try and have my current crossmember modified so it bolts together on both side just on the outside of the tranny mount. Probably build some adjustment in it so I can get the vent as close to the tunnel as possible and adjust my pinion angle from there. Distributor clearance is find etc.
Old 05-23-2008, 12:56 PM
NvrDun71 NvrDun71 is offline
Todd, clean out those PM's brotha...
71' Nova - LY6, T56
Closed Thread
