i would call marcus from SC&C he has some weld in watts links.. that clamp on the rear ens and weld on to tha frame (or brackets you make and bolt to the frame....) he is a sponsor here and will hook you up.. 610 346 8154
Im not sure that a mumford link is needed on a PT car as the center of gravity is so high that the rollcenter even with a watts is more than low enough... the watts SC&C sells also has the feature of having adjustable propellerheight so i think that a mimford would.. other than looking more "tech" just require a bigger rear sway bar...
Jake: Hit it.
