Old 06-02-2008, 05:26 AM
Default Help with gm # numbers
Can someone give me correct GM part numbers for these :
-Z06/LS7 corvette fuel filter
-LSx Fbody clutch actuating combo ( master and slave cylinder)
Thanks!!
63 Z06
Old 06-03-2008, 12:30 AM
Anybody
63 Z06
Old 06-03-2008, 08:24 AM
907rs's Avatar
907rs 907rs is offline
Have you tried http://www.gmpartsdirect.com/ ?
Bill
Old 06-03-2008, 09:04 AM
Originally Posted by 907rs View Post
Yes , no part numbers..
63 Z06
Old 06-03-2008, 09:22 AM
jannes_z-28's Avatar
jannes_z-28 jannes_z-28 is offline
They don't show partnumbers anymore.
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z/28 LS1/T56
www.protouring.se www.carphotos.se
Old 06-03-2008, 09:36 AM
I ound the numbers for you Joni,
Clutch main cylinder and rod #12565144
Clutch slave cylinder #15046288
I didn't find the filter but you can look yourself.
GM parts direct will show you the partnumbers when you checkout.
Jan
Jan Suhr
Stockholm, Sweden
Old 06-03-2008, 01:03 PM
Thumbs up
Jan
Thanks Jan!!!
The filter/regulator:
I just found in the pro-touring com at Z06/LS7 vettes dont have serviceable fuel filter ?? Could it be so ? Because i would like to use as much oem parts as possible. But i guess i can just put aftermarket regulator and filter just front of the tank and run single line up to the front.
Then the LSx Fbody clutch actuating combo ..
I check those part numbers here locally. I dont want modified kit like ats sells . If it brakes "middle of the nowhere" i have better change to get stock replacement part than custom. Besides it worked really good in my vette-i just dont understand why i lost the part numbers of it..
Then more mystery. In P-T.com forum member told it sell event the hose part separetly,wich i found really hard to believe,because they are pre filled with fluids too. I wonder what is all behind this. I allso got different Master cylinder part number:
"2002 Camaro LS motor 6-speed :
Clutch Master Cylinder pn-12570277 ( $144.00 plus freight )
Clutch Slave Cylinder pn-15046288 ( $123.00 plus freight )
These do not come as a combo.
Available separately.
The line doesn't come with them either
Howcome this( too ) can be so difficult
63 Z06
Old 06-03-2008, 01:11 PM
Jan
Jan check this out :
http://cgi.ebay.com/ebaymotors/01-02...spagenameZWD1V
Is there a reason why i could not use V6 model ?
Jan[/QUOTE]
63 Z06
Old 06-03-2008, 02:16 PM
I think they are the same, looks like the one I have.
About the regulator/filter. You could always use the 1999 Corvette part. Look at LS1tech.com. You'll get all your answers there.
Jan
Jan Suhr
Stockholm, Sweden
Old 06-03-2008, 07:07 PM
brownz brownz is offline
i have the fuel filter that you need in my hand so this is the right part# that you will need 10299146
