Old 07-11-2008, 11:22 PM
jannes_z-28's Avatar
jannes_z-28 jannes_z-28 is offline
I remember seeing somewhere that to double your speed you need 8 times more power.
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z/28 LS1/T56
www.protouring.se www.carphotos.se
Old 07-12-2008, 01:08 AM
holschen's Avatar
holschen holschen is offline
Default hmm
weight,aerodynamics,enginedisplaysment,how wide tires u have(wider=slower),enginepower,drivetrain slip,
hmm my english is what it is ,sorry
if u wear a helmet ur speed will slow remarkably
camaro69-l92+6l80e-
speedtech(LCA)-ats Street-Comp AFX-unisteer r&p-VariShock
camaro 5gen rear
Hydratech Brake Booster
movit brakes 380mm 6piston front- brembo 465mm 4piston rear
275/30-19 front-325/25-20 rear
19x9f 20x12r cray scorpions
Old 07-12-2008, 01:01 PM
JamesJ JamesJ is offline
Originally Posted by holschen View Post
weight
Unless it a short distance then weight does not matter much at all.
James J.
Old 07-13-2008, 12:33 PM
holschen's Avatar
ok so you need as many hp to reach 300kph in a 1ibs car (if you could make one)as you need in a 3000ibs car???
good luck!!
camaro69-l92+6l80e-
camaro 5gen rear
Old 07-13-2008, 08:05 PM
good luck!!
Pretty much...
James J.
Old 07-17-2008, 08:07 AM
dave96dcm dave96dcm is offline
Weight does not matter that much, most boneville cars are over 5k lbs.
Old 07-17-2008, 08:17 AM
Lateral-g Moderator
Bring a stewardess b/c if will probably take flight!
Old 07-12-2008, 12:38 PM
deuce_454's Avatar
Jan
the drag increases geometrically with speed, "speed squared" so to speak,, so its double the speed = four times the power...
the eight fold is if you want to accelerate to twice the speed in the same distance....
but i see your point... do a full throttle run, record the speed and when the car is dyno´ed ill know how much power i have at the wheels at that given rpm.. and then its relatively simple math to figure out how much power i need then (assuming that it takes zero Hp to go zero Hp and not account for rolling resistance will give an over estimate of power needed)
Jake: Hit it.
