Old 07-18-2008, 09:16 AM
kwhizz's Avatar
kwhizz kwhizz is offline
Jody...........What's the latest..........?????
Ken
Old 07-18-2008, 11:11 AM
camcojb camcojb is online now
Ken
Ken,
the crank was tapping the side of the pan after I re-did the turbo drain line; it was pushing the oil filter hoses into the side of the pan enough to make it just hit on the front throw. It was super close to begin with since I run a Callies stroker crank. I had pulled the engine to powdercoat the pan, and so I clearanced it first and then took it to the powdercoater. I went ahead and pulled the engine down just to have a look, everythings perfect.
It's almost back together, just waiting for a head gasket from Chevrolet which should be here today, and the pan from the powdercoater.
Old 07-18-2008, 01:05 PM
ccracin's Avatar
ccracin ccracin is offline
Jody,
You are certainly dedicated to this project. Pulling that work of art apart, wow. Better safe than sorry! I hope to get to see it some day. Great work.
Later,
Chad
Instagram - @cctek
68 Chevy Pickup Project
