Old 07-20-2008, 05:12 AM
tony69 tony69 is offline
Unhappy Humming noise
hi guy's
i just build a 427 small block stroked to a 450cu in. with a tko 600 and a strange rear end. at a specific engine speed and car speed as well the car has a humming sound. you can also feel it in the stick shifter. its a very tight humming sound. what can it be? any suggestion ?
tony69
Old 08-01-2008, 08:53 AM
AJSZR2326 AJSZR2326 is offline
get used to it? my tko makes noises too
Old 09-13-2008, 02:49 AM
deuce_454's Avatar
my guess is driveshaft harmonics.. check your angles and make sure the shaft is ballanced
Jake: Hit it.
