Old 07-31-2008, 09:57 PM
tjbruning tjbruning is offline
Originally Posted by HWY Nova View Post
No... That would be Tim Haden's brother! HA!
--Eric
Old 07-31-2008, 10:01 PM
HWY Nova HWY Nova is offline
Default Credit....
Marty,
You are correct: Kenny and his crew are doing an awesome job! Soon you'll be thanking Tracy for your interior...... and then it should be DONE!
I'm jealous..... I'm only six weeks into my project.....
--Eric
ET
63 Nova Coupe
63 Nova Wagon
62 Nova Convertible
Old 08-01-2008, 08:26 AM
syborg tt's Avatar
Marty,
--Eric
yep, they are a great group of guys.
6 weeks - wow just wait it's a blast
marty-mj
Old 08-01-2008, 12:46 PM
Young Gun Young Gun is offline
you gonna have it at the chicagoland goodguys?
Old 08-01-2008, 01:45 PM
kennyd's Avatar
kennyd kennyd is offline
i will anwser that , NO . but he WILL have the brown 57 .
Old 08-01-2008, 01:49 PM
ironworks's Avatar
So does this Kenny Davis guy do monster notches, fast bags and body drops. Cuz your mini truck is SIC BRAW.
I'm looking to get a walk through with a dancing bed on my triple axle B2000.
Looking good boys, I wonder who will finish first. I have pretty SIC sport truck coming togther myself.
Old 08-06-2008, 11:26 AM
syborg tt's Avatar
Good Afternoon All,
Kenny Has been cranking on the truck.
In order to put the chassis together he needed to get a list of Hardware together.
Once it was together we put an order in with Totally Stainless.
Lets just say "Doc" is awesome to work with.
He took my list and pulled it all together in one day.
You say no big Deal - well check out the list at the bottom of this post.
It's 963pcs total and there are still plenty more to order.
This is just the hardware for the chassis.
All of the hardware come bagged & tagged.
All Kenny has to do is look for the bag that states the area he's working
and he's off to the races.
Just another close up of the parts.
marty-mj
Old 08-06-2008, 11:27 AM
syborg tt's Avatar
Kenny & Travis putting it all together.
It's starting to look like something.
As promised here is the hardware list - WOW !!
Bolt & Washer S-10 Steering Box
1 pcs --- 12mm Clevis Washer - 25mm OD - 3mm Thick - 0.473in ID - .984in oD - .118 THK
1 pcs --- 7/16-14 x 4.18 small Hex Head - Large Flange - High Strength
Upper Ball Joints
8 pcs --- 1/4-20 x 1 Twelve Point - Large Flange - .56in - High Strength
8 pcs --- 1/4 AN Flat Washer - .50in OD - 18-8 SS 6mm Flat Washer
Upper Control Arm
4 pcs --- 1/2-20 x 3 Hex Flange Head - 17-4 PH High Strength
4 pcs --- 1/2-20 Tall Nut - 304 SS - 70,000 Yeild Strength
4 pcs --- 1/2 Split Lock - 18-8 SS
4 pcs --- MS 818 Flat Washer - 1.06in OD - 18-8 SS
Pivot Shaft
4 pcs --- 5/8-18 Nylon Locking Nut - 18-8 SS
4 pcs --- 5/8 x 1 3/4 Body Mount Washer - 1.81 OD - 18-8 SS
Lower Control Arms: ( Drill out 12mm Bushings to 1/2" )
2 pcs --- 1/2-13 x 4 Flanged Hex Head - 17-4 PH High Strength
2 pcs --- 1/2-13 Nylon Locking Nut - 18-8 SS
2 pcs --- 9/16-12 x 4 3/4 hex Flange Head - 17-4 PH High Strength
2 pcs --- 9/16-12 Nylon Locking Nut - 18-8 SS
Idler Arm
4 pcs --- 7/16-14 x 1 Twelve Point - Large Flange - High Strength
4 pcs --- 7/16 AN Flat Washer - .75" OD - 18-8 SS
Caliper Bolts
10 pcs --- 7/16-20 x 2 Twelve Point - Small Flange High Strength
10 pcs --- 7/16 AN Flat Washer - .75in OD - 18-8 SS
Caliper Brackets
opps we ordered the wrong size
8 pcs --- 3/8-24 x 1 Twelve Point - High Strength
4 pcs --- 3/8-24 x 1 1/2 Twelve Point Flange Head High Strength
4 pcs --- 3/8-24 x 2 Twelve Point - High Strength
16 pcs --- 3/8 AN Flat Washer - .63in OD - 18-8 SS 10mm Flat Washer - 16.0 mm OD
Rotor to Hats
32 pcs --- 5/16-18 x 1 Twelve Point - Large Flange - .63in - High Strength
32 pcs --- 8mm Standard Flat Washer - 15.7mm OD 5/16 Flat Washer - .62 OD - Din 125 A2
Four Link & Panhard Bar
10 pcs --- 5/8-11 x 3 Flanged Hex Head - 17-4 PH - High Stength
10 pcs --- 5/8-11 Nylon Locking Nut - 18-8 SS
20 pcs --- 16mm Standard Flat Washer - 29.7mm OD 5/8 Flat Washer
Front Sway Bar
4 pcs --- 3/8-16 x 1 1/4 twelve Point - Large Flange - .63in - High Strength
4 pcs --- 3/8 AN Flat Washer - .63in OD - 18-8 SS 10mm Flat Washer - 16.0 MM OD
Sway Bar Mount
4 pcs --- 1/4-28 x 1 Twelve Point - High Strength
8 pcs --- 1/4 AN Flat Washer - .50in OD - 18-8 SS 6mm Flat Washer - 12.7mm OD
4 pcs --- 1/4-28 Twelve Point Nut - High Strength
Rear Sway Bar
4 pcs --- 3/8-24 x 1 1/4 Twelve Point Flange Head High Strength
8 pcs --- 3/8 AN Flat Washer - .63in OD - 18-8 SS 10mm Flat Washer - 16.0mm OD
4 pcs --- 3/8-24 Twelve Point Nut - High Strength
Front Air Bag
Rear Air Bag
4 pcs --- 1/2-13 x 2 1/4in Hex Flange Head - High Strength - 17-4 PH
8 pcs --- 1/2 AN Flat Washer - .875in OD - 18-8 SS 12mm Flat Washer: 22.2mm OD
4 pcs --- 1/2-13 Nylon Locking Nut - 18-8 SS
Transmission Mount
4 pcs --- 3/8-24 x 1 1/2 Six Point (Small Hex Flanged Head) High Strength
8 pcs --- MS 813 Flat Washer - .875in OD - 18-8 SS
Fuel Cell, Air Tank & Roll Bar
30 pcs --- 3/8-16 x 1 Twelve Point - Large Flange - .63in - High Strength
30 pcs --- 3/8 AN Flat Washer - .63in OD - 18-8 SS 10mm Flat Washer - 16.0mm OD
Intercooler to Frame
4 pcs --- 5/16-24 x 1 1/4 Six Point (Small Hex Flange Head) High Strength
4 pcs --- 5/16-24 Twelve Point Nut High Strength
8 pcs --- 8mm Standard Flat Washer
Fuel Pump, Cooler Lines & Ground Studs
16 pcs --- 1/4-20 Serrated Flange Nut 18-8 SS
16 pcs --- MS 809 Flat Washer - .56in OD 6mm Flat Washer - 14.2mm OD - 18-8 SS
Fuel Pump Ground Stud
1 pcs --- 3/8-16 Serrated Flange Nut - 18-8 SS
1 pcs --- 10mm (0.394 ID) Clevis Washer, 20.5mm (.812) OD, 2.5mm 12 GA. Thick DIN #1440-A2
Dust Sheild
6 pcs --- 3/8-16 x 1 1/4 Twelve Point - Large Flange - .63in - High Strength
6 pcs --- 3/8 AN Flat Washer - .63in OD - 18-8 SS 10mm Flat Washer - 16.0mm OD
1 pcs --- Bellhousing Kit - General Motors Vehicles - Automatic Transmission or Aluminum Bellhousing - 1 1/2" High Strength - Small Hex Head
Transmission Pan
20 pcs --- 5/16-18 x 1 Twelve Point - Large Flange - .63in - High Strength
20 pcs --- 8mm Standard Flat Washer - 15.7mm OD 5/16 Flat Washer - .62in OD - DIN 125 A2
Inner Fender
30 pcs --- 1/4-20 x 1/2 Twelve Point - Large Flange High Strength
pcs --- missing washer -- Forgot to Order
Misc Bolts
2 pcs --- 6-1.0 x 25mm 12 Point - High Strength
2 pcs --- 8-1.25mm x 25mm 12 Point - High Strength
20 pcs --- 3/8-24 x 1 Twelve Point - High Strength
28 pcs --- 3/8-24 x 1 1/4 Twelve Point - High Strength
6 pcs --- 3/8-24 x 1 1/2 Twelve Point - High Strength
50 pcs --- 3/8-24 Twelve Point Nut - High Strength
100 pcs --- 3/8 AN Flat Washer - .63in OD - 18-8 SS 10mm Flat Washer - 16.0mm OD
100 pcs --- MS813 Flat Washer 0 .875in OD - 18-8 SS
20 pcs --- 5/16-24 x 1 Twelve Point - Large Flange - .63in - High Strength
20 pcs --- 5/16-24 Twelve Point Nut High Strength
40 pcs --- 8mm Standard Flat Washer - 15.7mm OD 5-16 Flat Washer - .63in OD - DIN 125 A2
20 pcs --- 1/4-28 x 1 Twelve Point - High Strength
20 pcs --- 1/4-28 twelve Point Nut - High Strength
40 pcs --- 1/4 AN Flat Washer - .50in OD - 18-8 SS 6mm Flat Washer - 12.7mm OD
marty-mj
Old 08-06-2008, 07:40 PM
black2002ls black2002ls is offline
Its looking good Marty, not long now!
1/12th scale 1969 Sunset Orange Metallic Camaro Pro Touring Style>>
Progress Thread
Artwork Page
Old 08-12-2008, 08:50 PM
syborg tt's Avatar
Good Morning All,
Quick Update - Syborg in Print
Make sure you pick up the September Issue of Super Rod Magazine.
Yep, The mighty Mini has struck again.
I want to thank Josh for taking these incredible pictures.
Fuel Injected Media - Revolution Industries, www.rev-in.com
www.sportmachines.com www.syborgtwinturbo.com www.kdhotrods.com www.compfab.com
www.rockfordracecraft.com www.autometer.com www.airbagparts.com www.nitrousexpress.com
www.hydroillusions.com www.revolutionbrake.com www.stainlessworks.net www.billetspecialties.com
www.docskustom.com www.flamingriver.com www.raceprovenmotors.com www.wiresandpliers.com
www.bowlertransmissions.com www.ridetech.com www.hoodpins.net www.carterhickmandesigns.com
www.goodmarkindustries.com www.juxtaposedmachines.com www.belltechcorp.com
www.sparcousa.com www.kicker.com
www.recoveryroominteriors.com
graphic's by --- [email protected]
marty-mj
