Old 08-10-2008, 05:55 PM
1960LesPaul's Avatar
1960LesPaul 1960LesPaul is offline
Tim is this what you are referring to? http://www.scandc.com/currectrac.htm Also all I want to do is shore the rearend up and stop the rub. I am sure if I were to only replace the rear bushings I would be ok so with that said what is the best bang for the buck. Since I am going to have to replace bushings then I might as well upgrade a bit within reason. I am running a mild 454. If I were to run the arms that I listed (currectrac) with this rear sway bar (Hellwig) http://www.scandc.com/hellwigswaybars.htm would that do the trick? Which Varishock 1 or 2 and what would you suggest for a rear spring? Keep in mind that I want to lower the car some.
