Old 08-21-2008, 03:31 PM
*rayman*'s Avatar
*rayman* *rayman* is offline
Default First Gen: Door stuck shut problem
How many of you guys have had problems with a stuck door during the assembly part?
I have new latches, new strikers, new exterior handles, new lock barrels, nice tight hinges, new rubbers installed.
LH Door works like a treat, and closes firmly. (did originally have problems here with door buinding shut, until i replaced worn striker and door latch mech)
I have spent countless hours playing with the RH door, but it will close, and get stuck closed. I can release the latch by putting a small flatblade screwdriver into the latch and overriding the latch.... Latches have been lubed up with white lithium grease, and work fine out of the car.
This is so frustrating, i just want to get it back together and get the interior finished off.
I've read through a lot of posts on camaros.net and there seems to be heaps of guys have encountered the problem there... most with worn door mechs though....
68 BB SS Camaro - building it in Australia, where everything costs twice as much as it costs in the U.S.
Fuel prices suck!
Old 08-22-2008, 06:11 AM
CCandR's Avatar
CCandR CCandR is offline
check the latch , make sure it opens without help - spring in latch could be broken....dont like the overseas latch, doesn't fit the door properly where it mounts.
Old 08-22-2008, 06:17 AM
dhutton dhutton is offline
This happened to me once when I had the striker misaligned. Moving it cured the problem.
Old 08-24-2008, 03:04 PM
*rayman*'s Avatar
Will try moving the striker out a little and see if that fixes it... I bought OER latches and not the real cheap and nasty ones.
These little things can be so frustrating and really hold progress up on reassembly.
Fuel prices suck!
