Old 08-23-2008, 05:11 PM
G_T's Avatar
G_T G_T is offline
Default weight
Thanks Frank. You are correct - if I trim the lip, then outer wheel well will rub (has a bulge) I can modify that if needed.
What's the min recommend clearance on the lip?
How about recommendations on suspension travel?
Should be pretty stiff - is a compression distance of 2" enough? If not, I'll have to modify the outer wheel well - I can get up to 4" with little modification (I should probably just do it).
I weighed the original steel wheels vs.the Forgelines. You are right that the wheels are light! The shipping boxes with 1 front and 1 rear wheel weighed 30lbs.
The original 14" wheels with 205 tires was a portly 49 lbs.
The front forgelines with 245's weigh only 2-1/2 lbs more (51 lbs) Most of the additional weight is the tire.
The 335's & wheel was 63 lbs. Too bad they don't make lighter tires Couldn't imagine what a 18"x12" steel wheel & a 335 tire would weigh...
Here is a better picture - outside, that shows how the satin black outers give the tire a thicker look...
1970 Dodge Charger: Viper Gen III V10/6spd, RMS Alterkation, Moser 60, 4x14" Wilwoods, RMS Street-Lynx triangulated four link. Currently mocking up...
Old 08-23-2008, 05:53 PM
What's the min recommend clearance on the lip? 1/2" is pushing it, 3/4" would be better.
How about recommendations on suspension travel? You need 3 to 4 inch travel for those "hard bumps"
Should be pretty stiff - is a compression distance of 2" enough? If not, I'll have to modify the outer wheel well - I can get up to 4" with little modification (I should probably just do it). Just do it!
Here is a better picture - outside, that shows how the satin black outers give the tire a thicker look... Simply Bad Ass! I can't wait to see this car done. thanks for putting our wheels on it
Frank Serafine
Old 08-23-2008, 05:57 PM
G_T's Avatar
G_T G_T is offline
Thank you Frank for the help thus far!
I'll give you a call on Monday with the axle width.
Old 08-24-2008, 10:31 AM
GHOSTDANCER GHOSTDANCER is offline
Great looking wheels
Do you have a project thread
Old 08-26-2008, 08:47 PM
hotrod468's Avatar
hotrod468 hotrod468 is offline
Hello GT/Frank,
The wheel/tire combo looks great!
I'm about ready to order Forgelines from Frank as well. By the way, what are the offsets/backspacing on the front and rear wheels?
Since I am ordering my Moser rearend from Frank too I am trying to decide what size outside rim lip to buy. I like the distance on your wheels. Knowing these dimensions would give me a starting point.
Thanks for your time,
Ray
Old 08-26-2008, 08:54 PM
G_T's Avatar
G_T G_T is offline
Well Frank will set you up. I just spoke with him today to spec out my Moser 60.
I had Frank give me the max BS (deepest dish) he could on the rears. The backs were 18x12 wheels with 5.2BS. You can go deeper if you go with a larger diameter wheel. I am running the ZX3P's - the premium line I believe has a bit thicker hub - if you go with the race wheel (e.g. ZX3R) I think you can go just a little deeper too. I didn't like the race wheel center caps.
Fronts are 18x8 with 5.2BS (spec'd this way for clearance on my front end - could have gone wider and deeper but I wanted a particular look).
Old 08-26-2008, 09:29 PM
hotrod468's Avatar
Thanks for the information. I am converting my car over from the "Pro Street" look to the "Pro Touring" look so I am trying to elimante the "deep" dish look on back that I already had. I had 15"x14" wheels on the car with a 5-1/2" backspacing (with a 46" housing end-to-housing end Ford 9" in the car). That gave me an outside/dish depth of roughly 8-1/2". In my opinion, that was too wide to give the car the proper look...
Your roughly 2.5" outside lip on your front wheels looks about what I am shooting for on the front of the car. I can adjust the front track with the control arm length on the front of my car to get to that lip. I am using 18" factory ZR-1 wheels on my car for my race tires and that is about what the corvette lip is on their 18"x10-1/2" wheels. To compliment this offset I planned on about 1-2" more outside lip on the rear wheels to flow with the fronts.
I was planning on a 100% matte black wheel on my car but after seeing the matte black lips with the gun metal centers on your wheels has got me thinking...
By the way, I am going with the ZX3R racing wheels on my car so the wheels do look just a slight bit different.
Thanks again for your help!
