Old 09-19-2008, 08:24 PM
awr68's Avatar
awr68 awr68 is offline
Good deal Mark!!
Tony
'68 Camaro
Old 09-19-2008, 08:59 PM
Looks good.
Old 09-20-2008, 05:31 AM
Looks good. I have found a few people who have had issues with the centering of the rear wheel in the opening. (wheel in too far forward) Apparantly it is part of the reason for the adsjustment of the lower arms.
Once you get the wheels on can you post a pic as well as let us know if you was ok out of the Box or was too far forward?
Old 09-20-2008, 05:48 AM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
I had them on out of the box originally with no problem when I took measurements, from what I undestand the people having issues were using 19 or 20 rims. I havent gotten the rims yet but my plan is 18's so I should be ok.
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
Old 09-20-2008, 06:05 AM
68protouring454's Avatar
vins car with 18s the tires are way forward in the wheel house
Jake's Rod Shop
Old 09-20-2008, 06:38 AM
Not sure I get that one. Center is center no matter if your 10 inches from it with 20 Inch wheels 9 inches with 18's ect. I realise that the effect is more noticable the further you go.
Old 09-20-2008, 10:14 AM
They are definitely toward the front slightly. When you go to a 19 from a 18 your tread diameter increases by 1.7". I measured mine recently on the centerline of the wheel center cap. I have 1" in the front and 2" in the back. It definitely could go back .5 inches but I don't have any rubbing as of yet and my drive shaft would be to damn short. I do like the idea of the swivel links and easy alignment and pinion adjustments. I'll eventually swap mine out. But for now I want to drive my car!!!!!!
Old 09-20-2008, 03:30 PM
What Mark (Bigtyme1) is trying to say is with the old stand by 335 / 30 / 18 tire which is less then 26" overall diameter, the none centering is not as noticable or problematic. However, when you stuff a nearly 27" tall 345 / 30 / 19 (Like Payback / EmptyNest), it becomes more obvious and more problematic. However not super noticable as Vegas never noticed until I asked him to measure.
However, the same problem exist on many leaf springs cars. We have been dealing with this in the drag race world for years. You can fit a 28" tire on these cars if you move the rear back a half inch. It is worse on some cars then others.
But yes, another reason we built the adjustability into our kit. Makes it nice to center the wheel.
Vegas, we just did Danny's 68, moved the rear back a 1/2", driveshaft is fine.
Frank Serafine
