Old 10-30-2008, 10:33 AM
slck6t9's Avatar
slck6t9 slck6t9 is offline
I like these two choice's better.
Old 10-30-2008, 10:40 AM
69MyWay's Avatar
69MyWay 69MyWay is offline
Thanks man...
does anybody know the exact maximum size and offset you can stuff in there on a stock suspension?
I get a little rub in the rear under hard turning or hitting bumps when I have the rear seat full of people - not enough to be an issue with the stock rear 18" C5 wheels
The front rub when I turn at a decent speed, or if I go into a drive or some sort of bump up. I assume 7" rim in the front with a 235 40 18 might stop that...but in the rear I would like to keep it maxed.
I'm going back to a stock width rear axle - would like to go 10 x 19 on the rim...and am curious about back spacing.
