Old 09-10-2005, 11:03 AM
Boulder69 Boulder69 is offline
Question 295/35/18 for 1969 Camaro without minitubs?
I have a 69 camaro with a '95 LT1 and 700r4. Next up on the project list is to replace the mullet-mags (15 inch Centerlines) with some 17 or 18 inch wheels and tires to make room for big brakes. Here is my question:
Can you fit 295s on the rear of a 69 without a minitub? Mark Stielow's "Thrasher Camaro" had this size, and the new Unique Performance/Foose '69 has them as well. Most threads on this site say 275 is the biggest, but I thought the 69 had a little more room in the back and with a little fender lip trimming the 295s should fit?
Anyone have this setup? What rim size and backspacing did you go with?
Thanks from a newbie to the site. -eric in boulder
Old 09-10-2005, 11:25 AM
Pretty sure the Thrasher had 275's. I'll get Charley in here to confirm. I'd think a 295 will rub some without a mini-tub UNLESS you keep the rear of the car high enough it can't come down on the tire. But for the ride height most people want without a gap between the tire and fender lip it won't fit in my opinion without a bit or rubbing. It does fit in there on the Foose car though, but they likely rolled the fenders as much as possible, and it probably rubs on the inside sometimes. The 275 was close enough to do that also.
Old 09-10-2005, 12:21 PM
clill's Avatar
clill clill is offline
Stielow says the rears on the Thrasher are 285-35-18's on a 10" rim.
Old 09-11-2005, 01:25 AM
4mm 4mm is offline
Yep, that's what my new car has. Purchased Tom Izzo's car a couple of weeks ago and it has 295/35/18's. There is no rubbing whatsover and the lowered stance looks great to me. Of course, it has nice pricey wheels with custom backspacing that nailed the positioning...that's one of the keys, IMO.
Here are a couple of pics so you can see the way the tire/wheel size would look.
Old 09-11-2005, 11:06 AM
4MMM - Nice looking car. Any chance you know the backspacing and width of your rear wheels? Thanks. -eric
Old 09-11-2005, 06:30 PM
Clockwork's Avatar
Clockwork Clockwork is offline
I'm running 285 40 17 with 5.5 bs on my 69 and it is a tight fit. Once I lowered it the lips did have to be rolled a bit, no biggie.
Dean
Old 09-12-2005, 12:21 PM
CAMAROBOY69 CAMAROBOY69 is offline
Originally Posted by 4MuscleMachinesMan
Yep, that's what my new car has. Purchased Tom Izzo's car a couple of weeks ago and it has 285/35/18's. There is no rubbing whatsover and the lowered stance looks great to me. Of course, it has nice pricey wheels with custom backspacing that nailed the positioning...that's one of the keys, IMO.
I bought my 4" hood off of that car. Tom Izzos car is absolutely awesome. Congrats on the purchase. I didnt realize it had 285/35-18. My car is a little lower than his and if I tried to put 285 on there I think I would have some minor rubbing. Especially pulliing into angled driveways.
Adam_______Offical Car Name "ILLUSION"
383 Stroker, Stock cast heads, T-56 tranny, 4.11 gears, 2002 T/A dash, 4th gen interior including seatbelts, power lumbar seats, 18" Budnik Wheels,Hydratech Hydraboost
ILLUSION Website
--------------My Car on Lateral-g.net----------- Need something designed?-AdFabDesign
Old 09-12-2005, 11:51 PM
4mm 4mm is offline
No problem Eric, I just won't get to the car until the weekend after this one since my job has me tied down for a while. I will definitely keep you posted.
Frank
Old 09-13-2005, 07:18 AM
Steve Chryssos's Avatar
The 275 formula is based on two things:
1) Off the rack wheels where width and backspacing availability is limited.
2) 100% stock: No modifications to wheelwell lips or any other massaging. Given those two guidelines, a 275 tire on a 9.5" wheel is the maximum "no brainer" package.
If, on the other hand, you want to get creative--and have money for custom size/backspace wheels the 285 tire will fit, and maybe you can even jam a 295 on a 69 if the car is not too low (but I don't recommend it). Custom wheel manufacturers will sell wheels in .5" width increments and .5" backspace or even .25" backspacing increments.
285mm converts to 11.22" You have a little more than that minimum clearance in stock form. The minimum clearance is right around the 10 o' clock position in the wheelwell. The project becomes way easier if you roll the wheelwell lips (Actually, it's almost mandatory). A 10"/285 combo with 5.5" to 5.75" back is fairly easy. When you're running such tight clearances, be prepared for a lot of measuring and potential do-overs. Don't rely full on others backspacing measurements as your car may vary (even from side to side). So you still have to measure.
So if you are creative and ambitious, you can stuff that extra .5" or more of rubber without minitubs. It's just way easier to either run that off-the-shelf 275 combo or get in there and hog out the area with DSE minitubs. The minitub kit takes quite a bit of of work, but obviously a whole world of options opens up.
In the case of my own 68 Camaro 285/10" with DSE 3" springs combo, I will be milling .200" off the mounting pads (offset) of my rear wheels to tweak my clearances. 'Cause I just ruined a tire on a road trip. You know: measure once, cut twice.
________________
Steve Chryssos
Ridetech.com
Old 04-04-2006, 08:44 PM
6D9 6D9 is offline
4MM, I am also interested in the bs on the wheels. Are they 9.5's or 10's??
I would think its safer to go with 5.75bs than the 5.5's so you can use a small spacer if needed?? Or maybe 5.625 bs??
