Old 10-04-2008, 12:37 PM
Fastlane_Fab Fastlane_Fab is offline
Default Frame Table
I am going to start building a frame/chassis table and was wondering what the length, width of anyone that has one should be?
Old 10-04-2008, 01:39 PM
J2SpeedandCustom J2SpeedandCustom is offline
How big of a car are you working on? Do you want the wheels/tires to rest on the outer frame rails?
The one I built is 18' long and 5' wide.
Jeff Allen
J2 Speed and Custom
Old 10-05-2008, 08:41 AM
Ketzer's Avatar
Ketzer Ketzer is offline
I'm planning to do mine 20x6. 2x4or6 - 1/8th wall main structure. I'm thinking 2ft off the ground. Heavy casters with a flip down stabilizer on each leg.
Would be great to see pics of some of the pros tables, and things that they would suggest?
Jeff-
Old 10-05-2008, 07:58 PM
Blake Foster's Avatar
WE built one out of 12" x 1/4 I beam, maybe over kill but it sure dont move. we put big 12" castors on it and 1 1/4 leveling bolts on all four corners. and we dont weld to it, we used to have a 2x4x1/4 wall table and it moved arround to much. the other option but its expensive is a 5x10x 1" plate but almost impossible to move, our table for building the subframes is 4x8x1" and it weight about 1000 lbs
Blake Foster
www.speedtechperformance.com
Old 10-05-2008, 08:54 PM
I'm not a pro - but built one for my 356G project. It's a bolt together deal and when you pull the 2 upper or lower leg bolts - it folds flat for storage on the wall or against the wall. You can take it totally apart if you want to.
It has leveling casters on the 4 corners - with just levelers in the center posns. The casters are non-marr types so they don't tear up my epoxy floor but they are expensive - so I have an option for replacing them with a less expensive type and adding levelers in the lower hoop. If anyone is intersted I can post the measured drawings and materials listing.
PS, Make sure you set the lower rail above the height of your engine hoist so you can roll the hoist in/out.
Jim
Old 11-16-2008, 09:22 AM
65 347's Avatar
65 347 65 347 is offline
Jim
A list and drawings would be great. Thanks Mike
Old 11-22-2008, 11:41 AM
lhkustoms's Avatar
lhkustoms lhkustoms is offline
mine is made from 2-1/2 x 2-1/2 .188 wall it is 16'5" x 6' wide it was made from 100' of tubing
Luke Mau
L & H Kustoms
Old 11-22-2008, 12:08 PM
Fluid Power's Avatar
Jim,
Those caster/leveling things are cool. Where did you get them?
Darren
Old 11-22-2008, 01:22 PM
svp's Avatar
svp svp is offline
Our table is 9/16" Plate steel with I-beam legs and it's HEAVY!! We don't move it around since it's in a dedicated work space. It is balanced though so when empty we place a floor jack under the tube in the center that you can see hanging down from the middle and 2 people can move it around easily....but this isn't an option with a car on it. Our table has to fit multiple needs so if building one for a single project your dimensions and features need to be considered to fit your build needs.
Not a great picture but it's all I had handy....
Paul
Old 11-22-2008, 05:30 PM
tjbruning tjbruning is offline
sounds familiar...
