View Poll Results: Which rear suspension?
DSE's Quadra Link 104 45.61%
Alstons G Bar 77 33.77%
Leave the GW Cat 5's 17 7.46%
Just pull the trigger go Lateral Dynamics 30 13.16%
Voters: 228. You may not vote on this poll
Old 11-28-2008, 01:25 PM
FreddieCougar's Avatar
FreddieCougar FreddieCougar is offline
Actually, that is a production Chassisworks piece...those are the production finishes.
Tim
Tim McCain
[email protected]
instagram - timdrawscars
Old 11-28-2008, 06:33 PM
Also there are weld on lower brackets option available for a cleaner / non adapted look.
We have a few one order and will be putting one in my personal car in the next couple weeks. Cannot wait.
Frank Serafine
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Tim,
If I want to use my existing 12 bolt and not use the u-bolts provided, what provisions are there for weld on housing brackets for the lower arms?
Chris
Chris
Old 11-28-2008, 06:57 PM
We already sold a couple kits with weld on brackets. $50 more for weld on brackets.
Frank Serafine
Old 11-28-2008, 08:00 PM
MoparCar MoparCar is offline
Mopar E-body please.........
Old 11-28-2008, 08:44 PM
wedgehead wedgehead is offline
I second the E-body.
Old 11-29-2008, 10:35 AM
Marcus SC&C's Avatar
Thanks Tim, straight from the horses mouth. Poor wording on my part, I meant to say that the welding and surface finishes of the install (including the car ie. rusty parts) weren`t done yet.
The weld on brackets are a great option for a cleaner look. They`re almost elegant.
You can also get the swaybar mounts (either style) for $50 without the bar if you want to leave your options open but don`t want to cough up the extra for the whole bar now. Personally I love that adj. rate bar! The axle mounted bar with its billet arms is really pretty and functional too but tuning options make me all warm and fuzzy.
Maybe Tim can give some more info on other applications but last I talked to Chris there are plans to do a G-Link for all of the G-Bar applications so E-Body should be coming. Knowing how long this stuff takes to do right I suspect it may be a while though. In the mean time the existing G-Bar for those cars is a darn good system in it`s own right and we`ll be offering billet/greasable pivot ball double adj. arms for them like those on the G-Link. We have a Hellwig adj. rate rear swaybar for them as well. That gets you pretty close to a G-Link. Mark SC&C
Old 12-13-2008, 11:22 AM
Just a quick update on the G-Link. They`re shipping which is very cool! We also just became aware of a clearance issue when using the bolt on G-Link LCA brackets in mini tubbed applications. Some big mini tubb only wheel dia. and backspace combinations may not clear the lower coil over mounting bracket. The arms and brackets are much more beefy and they added additional adjustment holes so the brackets are a bit larger than the original G-Bar. If you want to run minitubbs just select the weld on lower arm mounts. They can be installed further inboard for clearance and Chassisworks is already working on instructions and an offset bushing kit for the front of the lower arms to preserve the correct geometry. The upper coilover mounts have plenty of holes for adjustment so no changes will be required there at all. CW will be doing at least one narrowed rear swaybar for minitubb applications and the adj. rate Hellwig rear bars should work as well. Thanks to Frank at Prodigy who`s helping Chassisworks with the fittment details on his mini tubbed cars. Mark SC&C
Old 12-22-2008, 02:20 PM
Tony@AirRideTech Tony@AirRideTech is offline
Supporting Vendor
http://www.ridetech.com/products/Chr...es-824-75.html
