Old 11-29-2008, 12:13 PM
rocketrod rocketrod is offline
I found a plastic applicator tip from a tube of RTV when I pulled the intake off my engine last fall.
Rod
1969 Camaro - LS2/4L70E
Old 11-29-2008, 12:55 PM
deuce_454's Avatar
i have done all my own enginework in the past untill a diesel (2.4 toyota i rebuilt) blew up on me and i started wondering of i shouldnt have a pro do the 427 for my impala.... so i did and when i pulled the distributor to prime the engine prior to startup (i had installed EVERYTHING at this point) the distributor drive rod was not installed.... the oilpump was there... but the drive was absent....
im back to doing my own enginework again!
Jake: Hit it.
Old 11-29-2008, 01:29 PM
pro-tour79's Avatar
pro-tour79 pro-tour79 is offline
Supporting Vendor
found a T-handle allen and a rag in the valley of an ARCA motor, had a guy stuff a rag in the intake on the dyno to keep things from going in the engine while at lunch, well after lunch they he forgot and put the carb on, the rag was sucked in and cracked the block as the piston tryed to compress the rag.
www.pro-touringf-body.com
Old 11-29-2008, 03:35 PM
Joey316G Joey316G is offline
Ok i used to work for a huge engine remanufacturer. We had an area of the asssembly line that would install timing covers and oil pans. On small block chevys, we used intermediate shafts (oil pump drive) with a pinned steel sleeve so all you had to do was drop it in the hole and then bolt the pump on. There is enough room to engage the shaft after everything is on and the engine is right side up. We would pull engines off the line randomly and put them on our dyno..this was my dept. SO we put this engine on the dyno and couldnt get the distributor seated for anything. So we pulled the engine off and pulled the pan to see what the deal is and presto!!!!!!!!
6 INCH 3/8 DRIVE EXTENSION....HAHAHHAHAHAHA
The resemblance to a melling intermediate shaft was uncanny....hahhahaaaa
1969 Camaro Pro Touring Project
1991 GMC SYclone
1985 Buick Gn w/ 87 engine
1970 Chevelle SS Clone
1967 Nova Future Pro Touring Car
1987 Formula Firebird
Old 11-30-2008, 01:59 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
I found a dime in the engine that blew up in my car. Kind of odd.
I also found a wrench welded to the hot section on one of the engines of an airplane I flew. The guy it belonged to swore up and down that it wasn't his, but it had his name engraved on it.
Curtis
