Old 12-03-2008, 11:18 AM
dhutton dhutton is offline
I had to dimple the fiberglass to clear the buttonhead screws that attach the fenders to the gusset. Even then the clearance to the fenders is very tight, I cannot install the fender bumpers. I could probably add more dimples for the fender bumpers but the fit is so tight that I don't think they are needed. It took quite a lot of trimming just to get it to clear the fenders. I think the gaps are around 1/16" on each side. Sounds like Frank did a lot more trimming.
I did finally get the hood latch to work.
Make sure you have your body guy do a mock up soon.
The metal hood has to be better (how could it be any worse?) but it's hard to spend another $1300 after spending $800 or so on the fiberglass hood...
Old 12-03-2008, 11:35 AM
I have not. I am building another one and will use the steel hood this time.
Frank Serafine
Old 12-03-2008, 04:03 PM
almcbri's Avatar
almcbri almcbri is offline
looking good.
1968 Camaro LS1/T56, Hotchkis Springs, Tubular Arms, AFCO sway bar, C5 brakes, VWW 18" V40's http://s14.photobucket.com/albums/a3...1968%20Camaro/
Old 12-09-2008, 10:49 AM
ZMAN1969's Avatar
ZMAN1969 ZMAN1969 is offline
Default little more progress
Well we took the motor and got it bolted up to the trans, new LS6 clutch, slave friday evening- did it in the back of my pickup truck, tied it down and saturday went up to my body mans place - its about 40 mi each way which isnt bad but at least its not a $25 trip now, unfortunately with the colder weather he didnt get a chance to paint the fire wall so it didnt "make it home" but will be next trip we did pull the old 8.2 pont rear end and springs out. we figured up where the shock crossmember needs to be welded in the lower back half of the car will then get some paint on it and the built 8.5 rear end will be ready to install with the Hotchkis springs and hardware. was hoping to get that done but his welder was inop at that time - oh well, more delays but it was some progress.
We then turned our attention to the interior we pulled the steering column, all the wiring harness and all the rest of the insulation - thats falling apart anyway and we also used some body filler spreaders to scrape the cardboard like stuff off the roof - all in all, nasty dirty work that HAD to get done sometime! Dirty nasty stuff- blowing all that out of the car and then his shop I'm glad that its done! We did also manage to have some tasty beverages so it wasnt a total loss - next time out I should have some pics of the engine drop in and the rear getting put in it.
'69 Trans Am clone under construction -still!
LS6 6speed
69 R/S Z28 Daytona Yellow 302
90 Formula / Firehawk clone
1999 Firehawk
1969 Chevelle SS 396
Old 04-10-2009, 06:57 PM
ZMAN1969's Avatar
Default update
its been a while but finally got the rear end in and back on the tires
LS6 6speed
1999 Firehawk
Old 04-10-2009, 07:00 PM
ZMAN1969's Avatar
Default oh and the motors ready too
finally rolling again
LS6 6speed
1999 Firehawk
Old 04-11-2009, 05:49 PM
GHOSTDANCER GHOSTDANCER is offline
Looking good
