Old 12-29-2008, 12:53 PM
chicane's Avatar
chicane chicane is offline
Where exactly 'under the car' we you thinking...?? as this may point the direction to which type of cooler to use.
For instance, if you were thinking of under the floor board... a round tube/finned type would work better... and if you were thinking somewhere on or near the core support, a stack plate would be better suited. There are even a couple of cylindrical flow thru types that might be worth consideration.
Anyway... Setrab (or Earls) for a stack plate... and there are numerous tube type manufacturers, so the selection might be overwhelming... but Ron Davis, C&R, Griffen, Baker Precision and even Durale... have a few to choose from.
The question is... I guess... where were you thinking of mounting it ?
