The Autokraft pan is steel, I have one out in the garage. Nice pan, a little extra capacity because of the kickouts, and the ability to run a stock location filter. What I don't like about it is no provision for an oil temp sender or turbo drainbacks, but Kurt at Autokraft is very willing to work with you to add them and then replate the pan.
Champ makes the same pan you posted in steel also, for $200 less.
All that being said, as far as fab quality goes I haven't seen any nicer quality LSX swap pan than the ATS pan.
1969 Chevelle
