Old 01-10-2009, 01:25 PM
mazspeed's Avatar
mazspeed mazspeed is offline
Moser 12 bolt with the true track. No brainer.
Old 01-10-2009, 02:35 PM
Tiger's Avatar
Tiger Tiger is offline
I'd get a new 12 bolt and sell the 10bolt
André
2009 Chrysler 300C Touring.
3.0 liter V6 diesel, five speed auto.
1968 Chevelle Coupe.
355cid, Viper T56, Corvette C4 IRS (Dana 44) and C4 IFS. Porsche 6 and 4 piston Brembo's.
1980 Chevy Van (shortie G10).
355cid, TH350, 8.5" 10bolt posi and Belltech spindles.
*NOW PARTING OUT* 2000 BMW 540i Wagon*
Bikes
1968 Benelli City Bike
1990 Yamaha RD 350
1990 Yamaha TZR 125R
1991 Yamaha TZR 125R - RD350 engine, Aprilia RSV forks, RS250 wheels and shock
2010 Buell XB12SS
Old 01-10-2009, 02:38 PM
We do a lot of moser rears. You can get into a Moser that will handle the 500HP for a about $2100 to your door in the lower 48.
Your 8.2" 10 bolt can hold about 400 HP, so if you never plan to go much more horsepower then stock you should be OK.
Frank Serafine
Old 01-10-2009, 07:24 PM
latzoo latzoo is offline
Default Gears
What gear ratio would you suggest, 3:73, 4:11?
Old 01-10-2009, 07:47 PM
I like my true trac alot. Even with excessive tire spin the car stays managable. Bought mine from Frank.
Old 01-10-2009, 08:40 PM
JamesJ JamesJ is offline
That depends on tire size, trans gearing, and some other stuff, but most likely 3:73 unless you want something different
James J.
Old 01-10-2009, 09:09 PM
3.73 is a great gear and what I am running. I would urge you to get on some calculators and input your cars particulars and speeds you run the most. Classic Motorsports Groups has one.
Old 01-11-2009, 04:35 AM
deuce_454's Avatar
x2
bought mine from frank also....
Jake: Hit it.
Old 01-14-2009, 07:57 AM
ZMAN1969's Avatar
ZMAN1969 ZMAN1969 is offline
Default rear end
PM sent. Why not the 8.5 10 bolt? it will handle as much as the 12 bolt will. and 1/2 the price to build - thats why GM stopped building the 12 bolts. not needed any more the 8.5" is GM's HD rear end since then. I build and sell 8.5" rears - about 1000$ delivered to lower 48 states
'69 Trans Am clone under construction -still!
LS6 6speed
69 R/S Z28 Daytona Yellow 302
90 Formula / Firehawk clone
1999 Firehawk
1969 Chevelle SS 396
