Old 01-19-2009, 08:40 PM
67rstbkt 67rstbkt is offline
Nice
Old 01-20-2009, 08:44 AM
ProTouring442's Avatar
Very nice Cutlass.... I had an '86 442 before some woman ran a red light and t-boned it.
One question though, what's with the disgusting photobucket name?
Shiny Side Up!
Bill
You ever wonder what medieval cook looked at the guts of a pig and thought, "I bet if you washed out that poop tube, you could stuff it with meat and eat it."
Old 01-20-2009, 10:34 AM
Cutlass2181's Avatar
Cutlass2181 Cutlass2181 is offline
thanks, its going to be even nicer once im all finished with it. haha, my photobucket name is a nickname my brother calls me and he made the account for me so im stuck with it.
Old 01-21-2009, 08:25 PM
Today we did front brakes. put on new rotors, and pads. I also finally got the heads back, so i can start putting the motor back together this week. looks like its gunna be all done and assembled by the end of friday. I had the heads sent out to get ported, polished, new valves, springs, and paint. they are basically brand new heads.
Old 01-23-2009, 09:52 PM
today we reassembled most of the motor. got the heads on, cam in, intake manifold on, valve covers on, oil pan on, distributor in, and oil pump in. we still have a couple bolt ons left for tomorrow, like starter, carb, fuel pump, temp gauge, headers. everything went very smooth. no issues which was great, all the gaskets fit and it was a good productive day. tomorrow im also putting the front 2 tires on, putting the car on the ground to fix some other stuff, then the motor gets joined with the tranny and goes back in. forgot my camera so heres some cell phone pics.
took off the plastic on the heads to find out they were done very very well. their like brand new.
turbo 350 from the old set-up
Old 01-23-2009, 09:53 PM
ill have more pictures tomorrow.
Old 01-24-2009, 10:03 AM
Olds442NorthStar Olds442NorthStar is offline
Sweet. I have a very similar '82 I am hoping to get back on this summer. I've been too busy with other projects, work and school to mess with it.
What are you doing for springs? Factory G-body springs were pretty weak rated. I put together a spread sheet about 10 years ago that was added onto by another guy on the monte mailing lists that can still be found around the net:
http://www.maliburacing.com/coilspring.htm
It lists Moog replacement springs and their O.E. factory installations which are usually a bit cheaper than aftermarket. Have fun and keep us updated.
Rob S.
Old 01-24-2009, 10:00 PM
I didnt do the springs at all. i didnt even think about it, i thought they were fine. ill look into that list and consider it though. ive also gotta keep in my price range.
Today we worked on the tranny, and getting it ready to join with the engine. we made a little more progress on the engine, and put the front tires on. the car should be drivable, but not completely finished in about 3 weeks. here are pictures of the car from today.
Old 01-24-2009, 10:01 PM
i will keep your guys updated. let me know if you have any suggestions, i sure could use them.
Old 06-10-2009, 06:25 AM
olds olds is offline
Originally Posted by Cutlass2181 View Post
the car came with the traction bars on it from the previous owner. it does seem like they have no effect in regards to handling, but it feels like they pull the rear of the car down and let it grab when it shifts, chirping the tires. is this true? it looks like i have to take them off anyway to get to the rear shocks, so they might be removed completely.
Nice cutlass!
Try these - they're the best you can buy for your car:
http://www.scandc.com/currectrac.htm
Not sure if you posted it somewhere, but what size are your front tires? &backspacing on wheels. I like those
