Old 03-21-2009, 07:19 PM
qwkswede qwkswede is offline
Originally Posted by awr68 View Post
How about fabbing up a small bracket that mounts to one of the 3rd member studs?
I think thats going to be the plan for the center Tee fitting. I'll likely do that. But anchoring the other end of the lines to the axle tubes will be interesting. There are some places to drill holes and put some tabs on the shock mount areas. I just don't really like the idea of randomly drilling my own holes. Seems like something that DSE might have thought about when they built the axle assembly. Maybe I'm expecting too much. I was just hoping for some ideas from people who have done it.
-Ken
1968 Camaro Convertible project car.
1988 Volvo Wagon, 12 second grocery getter.
Old 03-21-2009, 08:03 PM
jpdeuce's Avatar
jpdeuce jpdeuce is offline
If its already powdercoated then your kind of limited to some type of bolt on bracket. The bear kits included the holding tabs that can be mounted using worm gear clamps but the clamps aren't very appealing. The brake Tee could be easily fastened to the top of the housing where the third member studs are.
Old 03-21-2009, 09:27 PM
Apogee Apogee is offline
Which Corvette calipers are you running in the rear? The C3 4-piston calipers are fixed and have an SAE port, so you don't need to run hoses with those. The C4, C5, C6(Z51) and C6 Z06 calipers all have 10mm banjo connections, so a hose is typically the easiest from a routing standpoint. Plus, I like to be able to remove the caliper from the rotor in order to pull an axle shaft or swap pads without having to break into the hydraulics if at all possible.
Tobin
KORE3
www.kore3.com
Old 03-21-2009, 10:26 PM
Good point Tobin. I ran mine with a junction block and bracket at the gear cover and no other tether points but the calipers are fixed. My brake lines are also behind the axle. I would have preferred they were tethered but there weren't any good options but some welding on my brand new painted rear end. If I have any problems, I'll be the first to let you know. I am beating the piss out of her every chance I get. LOL
Old 03-22-2009, 12:33 AM
Thanks Tobin!
Good and valuable info. Can you please tell me what is the size of the hard line fitting wich fits for the Z06 rear brake hose ends ?
63 Z06
Old 03-22-2009, 11:12 AM
Bow Tie 67's Avatar
Bow Tie 67 Bow Tie 67 is offline
I think I have better pics, but here is one. I welded tabs on top of the axle tubes, used AN bulkhead fittings with SS line to a T on top. I welded a bolt on the top of the 9" to mount the T / flex hose. If I did it again I would move the tab over to better facilitate using differential frame bump stops.\
Matt
Matt
Project: " Chain Reaction "
A.K.A. " BIG " by wife, biatch in garage.
1969 RS Camaro, L92 T56, Chassisworks sub, Quadra-Link, Bear, Ford 9".
Old 03-22-2009, 12:23 PM
Originally Posted by Bowtieracing View Post
Thanks Tobin!
Which Z06? C5 or C6? The C5 caliper hoses are all 10mm banjo by M10x1.0 female bubble flares whereas they switch to M10x1.0 female inverted flares on the C6 models...not sure why though. For most of these conversions, we would normally supply hoses with 3/8-24 SAE inverted flares to match the early GM applications, but that's the advantage to not using OE hoses.
To add something to what matt pointed out about moving the hard line to the rear of the axle, not only would it make room for bump stops but it also protects the hard line from gravel kicked up by the front tires. You'll see most OE applications run a hard line wrapped with a coiled wire gravel guard in places susceptible to rock damage.
Tobin
KORE3
www.kore3.com
