Old 03-26-2009, 10:12 PM
autoxcuda's Avatar
autoxcuda autoxcuda is offline
Originally Posted by moparnut View Post
Why not just try some standard leaf springs with the correct arch? I had these made and they sat just right for my application. The only thing is on a B body is the upper frame rail may have to be notched a little or the rearend will bottom out on hard bumps.
I agree. Just contact the hypercoil with the weight of the rear of the car, the rate you want, and how much arch you want/need when installed. ESPO Springs and Things I think would be a better help.
There are three or two hole front spring hangers. And you could install a rear slider with a bolt in plate to the frame. Add shim plates to get the right anti squat and ride height.
Steve
68 Cuda Autocrosser
Fall Fling XV
October 30, 2010 Saturday
Woodley Park, Van Nuys CA
350+ Mopars, 175+ swap, midways.
Spring Fling Speed Festival April 2011
5th annual, Willow Springs CA, 40+ Mopars,
Event Video 1 Event Video 2
