Old 03-20-2009, 02:40 PM
thedude327 thedude327 is offline
Default Anybody using shorty headers on a Second Gen Camaro?
Am looking for some pics of second gen camaros with shorty headers. If your using them , what brand and how was the fit?
Thanks for any replies
Paul
1973 Z28 Street-touring project.........
Old 03-22-2009, 03:29 PM
Am looking for fit info on Hedman shorty headers or Patriot clipster headers. Pics of install if available, and if there were any fitting problems.
Paul
Old 03-24-2009, 08:13 PM
SYDEWAYZ71's Avatar
SYDEWAYZ71 SYDEWAYZ71 is offline
Default headers
I ran Hedman Elites. (Mid lenths) They fit perfect!!! No massaging needed.. The only reason I removed them is because I swapped my auto trans for a manual.
Old 03-27-2009, 05:36 AM
Thanks for the info !!! Do you have any pics of them from when they were in your camaro?
Paul
Old 03-27-2009, 05:44 PM
BRETT ANDERSON BRETT ANDERSON is offline
Default Shorty headers
Sorry to ask a dumb question, but what engine are you using? LS1? I may have missed something earlier on. I used so direct replacement shorty headers for a 1998-2002 Camaro for the conversion in my 1973 Camaro. Hope I'm helping?
Old 03-27-2009, 07:32 PM
tony byram's Avatar
tony byram tony byram is offline
Im running the Hedman shorty hedders on my 1972 big block Camaro Z28, They fit fine and there are pics of it at Pro-touring.com. Ilke them, plenty of ground clearance too.
Old 03-28-2009, 06:51 AM
Not a dumb question at all. I should've put that info in my first post. I am interested in using shorty headers with a Gen 1 small block chevy engine. Am concerned about whether the headers would foul on the linkage from the automatic trans to the steering column. This linkage locks the steering wheel from turning with the trans in park. Some header companies indicate that this linkage needs to be removed or modified to use headers but I'm trying to find a shorty set that avoids this.
Thanks for any help with this
Paul
Old 04-11-2009, 08:28 AM
twentyover twentyover is offline
Running Hedman Elite shorties on Gen I sbc on a 70 1/2 F Body. I'm running a manual (hydro clutch) and trimmed the linkage tab. Eyeballing it I would guess it would clear OK
