Old 03-30-2009, 11:59 PM
jst8a5.0's Avatar
jst8a5.0 jst8a5.0 is offline
Post it in the classifieds. Maybe an LSx would be cheaper or better suited to your needs. They are getting more and more plentiful and can be steals sometimes. Just make sure that you get everything you need like wiring, computer, etc.
Micah Prudhomme
Concept Fabrication, LLC
Shop page:
http://www.facebook.com/ConceptFab2006
Shop channel: https://www.youtube.com/my_videos
Old 03-31-2009, 07:56 AM
72blackbird 72blackbird is offline
The LS-series are good motors, but for a second gen 'Bird I'd stay with pure Poncho power- less high tech but cooler and old school. I'm building a 455 for my '72 Bird this summer, but if I didn't get that 455 I would have built a 400/462 stroker out of a 400 2-bolt block, and put the 4-bolt splayed caps on it.
The big advantage with the stroker is the 4.25/3.0/6.8 combo lets you rev it faster than the 4.21/3.25/6.625 combo in a stock 455. The stroker is also alot easier on the bearings and stronger than the 455 in the main web area. Add a forged crank and aftermarket 4-bolt splayed caps and you can buzz that mill to 6500 all day. Of course you need to have heads that can use the RPM- some 310 cfm KRE's or wideport E-heads would do the job nicely. Add a solid roller and you're making 600+ hp/ 575+ ft-lbs on pump gas.
Geno
Old 03-31-2009, 04:08 PM
7firebird1's Avatar
7firebird1 7firebird1 is offline
Thank's guys. I think I will do that. To the classifieds it goes.
Old 05-29-2009, 06:00 AM
OLDFLM's Avatar
OLDFLM OLDFLM is offline
Default 78cc #13 heads
If you decide to stay with the 400 I’ve got a set of #13 heads… ready to bolt on and run! They flowed 220cfm @ 28” on Rocky Rotella’s bench with just a mild cleanup and were visually inspected by Jim Hand after porting.
They were professionally assembled with all the good stuff: Ferrea valves, Comp Springs, hardened seats etc. Let me know if you’re interested… made right at 400hp/400lbft in my 400 with a Bullet 224/230 .485/.491 110LSA cam.
I have a 71 too btw so let me know what you need or if you have any questions as I've probably researched it for you already! LOL
Welcome to the site! This is a great community of incredible people!!
V/R,
Ty
Ty Ingle, USAF Retired
FREEDOMBIRD
Old 06-02-2009, 12:55 AM
7firebird1's Avatar
Thanks Ty! Hey I would like to see some pics of your car!!
Old 06-02-2009, 02:13 PM
Josh69 Josh69 is offline
Edelbrock is bringing some D-ports to market as well. They should be priced comparable to the Kaufmans, flowing around 260cfm out of the box. Would be the perfect head for a street car under 500hp, and have the Edelbrock quality associated with it.
Something to keep an eye on....I know I am.
1969 Firebird, Black w/Parchment Arizen interior, 383 Pontiac Stroker (350/428 crank), TKO600, Moser 12 bolt, 18" TTII's, Hotchkis, GW, DSE, Speed Tech, Vintage A/C, etc.
Old 06-02-2009, 09:54 PM
7firebird1's Avatar
Thanks. Will keep that in mind.
