I was wondering about both duration and each pull. I know the old 112 and 122 magnachargers would be in the(IAT) high 180° range at the end of a pull. That is just crazy. I heard the new harrop designed rotors should knock off a whole lot of heat. Do you plan on running meth?
Well, a procharger you have to make your own brackets to fit in the car. Originally, I was considering a Rotex supercharger, but Kurt Urban from W2W showed me the photos of this supercharger, and it is pulley setup. I contacted Casey Wegner of Wegner Motorsports and he set me up with the pulley setup. I like on where the A/C is mounted on this setup. Customer service from Harrop has been great!
I used procharger brackets and it fits in the engine compartent of a 1st gen.
1969 Camaro LS2/T56 D1SC www.automotivedesigneng.com
