Old 04-16-2009, 12:02 AM
deuce_454's Avatar
i have installed a pair of TPIS prepared afr heads ane they werent that wonderfull.. they changed the plug angle and the weld plug came out of one of the old plug holes.. when i sent pictures they claimed to eb able to see from the tan color of the combustion chambers that the timomg was wrong so they refused to exchange them.. so ill never buy AFR again...
the issues with your motor sounds like the ring fit was off or the bores were too smooth... and perhaps he neglected to grease the rear seal prior to instalation..
anyway, good luck with the rebuild
Jake: Hit it.
Old 05-05-2009, 03:35 PM
jack67rs's Avatar
jack67rs jack67rs is offline
The motor has been tore down, so here's a list of the damage: The windage screen was trashed with about 8 pieces in the bottom of the pan. Turned out that when the pan was bolted on it shoved it up into the rods. The oil pump was studed but it hung up on the main stud and was'nt seating properly, probably lost some pressure and flow. The worst being the piston to bore clearance, instead of boring the cylinders .30 over he went .33 and the piston rocked back and forth scoring the piston skirts and cylinder walls. Not to mention the extra load the rings received. He also decked the block so that the piston came out of the hole .010 raising the compression on my blower motor, would of thought .010-.020 in the hole would of been better for the compression.
The heads checked out fine, could see the results of all the blow by, but valve and guides are fine.
So now I have 8 Ross pistons that might as well be paper weights and a block I don't know if we can salvage. I'm going to see the builder tommorow, but don't expect much from him. He probably won't be happy to here someone else tore it down, but I can't imagine him admitting to the damage. Problem is that if after seeing all the things that were wrong even if he offered to fix it, I would'nt want to take the chance of going through this in another 1000 or so miles!! we'll see how tommorow goes!
Tangerine 1967 camaro "Octane"
https://lateral-g.net/members/hodson/
Hot Rod cover Feb. 2008 "Homebuilt Hero"
Camaro Performers feature Car March 2008
Video on Webridestv.com
http://webridestv.com/showvideo.aspx?video=55306
Old 05-05-2009, 04:52 PM
Good luck Jack. I hope he owns up to it and atleast offers some part replacement.
