Old 04-30-2009, 09:03 AM
ElkyZO6 ElkyZO6 is offline
Keep up the good work and keep the pic's coming
Old 05-04-2009, 12:44 PM
LWillmann LWillmann is offline
Well, last week I did a test fit on the gauges in the dash. I just sat them in there to see how they look and this is what I found.
So, I found that I should be able to see everything just fine once the spacers for the gauge plate are in and everything is wired up and screwed into place like it should be.
I also did a little work on the car this weekend...
Installed the transmission mount, new crossmember and driveshaft. I then modified my old LT1 dual electric fan shroud to work on the Cutty radiator and set the radiator in the car and test fir the fan shroud in the car to see how well it will work, and turns out that with the fan shroud turned right-side up the bottom fan (driver's side) hits the steering box, but if I flip it, it is fine because the other fan sets furter from the edge of the shroud. The only bummer at the moment is that the wiring is up top, but maybe I can flip the fans in the shroud and put the wiring back at the bottom again. I hope the mounting holes aren't at odd locations on the fans.
So that's what I got done yesterday in a few hours, wasn't much, but it was something. Here's a few pics of the crossmember and the beefiness.
It's a hefty sucker, that's for sure. The 'humps' for the exhaust tubes are made from 1/2" thick steel. It's certainly a serious crossmember!
After getting everything up and in place, I cleaned the floor plan up getting all that old oil and road grime out of there. It looks a lot better under there now.
Still a long way to go, but a little closer at least!
