Old 05-30-2009, 07:37 PM
jcal87's Avatar
jcal87 jcal87 is offline
Default 2006 c6 wheels on a camaro
I'm buying either an Art Morrison front clip or a DSE as many of you already know but i wanna know if i buy some corvette wheels and tires will they work on the camaro?
1968 Camaro Blue
1968 Camaro SS (Sold)
Texas A&M Alumni
Old 05-30-2009, 09:32 PM
jcal87's Avatar
every time i post this none ever responds...
1968 Camaro Blue
Texas A&M Alumni
Old 05-30-2009, 09:52 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
What are you asking and with respect to which C6 wheels - standard C6 or Zo6?
Will the wheels work without adapters? No.
Will they rub? I'd ask your vendor. I would think with properly sized adapters standard C6 wheels would probably be okay. Z06's won't work out back without a minitub, and the front may be tight. Again, I'd ask your vendor.
Old 05-30-2009, 09:54 PM
jcal87's Avatar
zo6 front and back and why wouldn't they work without an adapter?
1968 Camaro Blue
Texas A&M Alumni
Old 05-30-2009, 11:15 PM
Mkelcy's Avatar
Wrong offset/backspacing. Have you tried searching on any of this?
Old 05-30-2009, 11:17 PM
jcal87's Avatar
no it seems like it would be to specific to search
1968 Camaro Blue
Texas A&M Alumni
Old 05-30-2009, 11:24 PM
Mkelcy's Avatar
For fit on the front you'll need to talk to DSE/AME for their experience and end up with spacers in the 1.75" to 1.875" range.
For the back end, you'll need to have minitubs and an appropriate spacer in the 1.75" to 2.00" range. Offset can be determined from Ebay ads (they often list offset specs) then go here for an explanation how to go from offset to back spacing http://www.skulte.com/adapterfaq.html.
Old 05-30-2009, 11:27 PM
jcal87's Avatar
alright I'll definitely give them a call appreciate the help man thanks.
1968 Camaro Blue
Texas A&M Alumni
Old 05-31-2009, 12:09 AM
https://lateral-g.net/king/ Payton is a cool dude...betting he'd point you in the right direction. You're going to need wheel some big honking will adapters I can guarantee you that unless you want to run an over width rear end. Your still going to need them up front regardless.
Old 05-31-2009, 10:59 AM
jcal87's Avatar
whats his user name on here because on his page it doesn't give his name or email
1968 Camaro Blue
Texas A&M Alumni
