Old 06-09-2009, 06:59 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
Originally Posted by Z06vette View Post
I emailed you a pic of my subframe. It doesnt look anything like factory subframe.
I sent you a detailed response, repeated here for others:
You've got two choices for both motor mounts and plates. Motor mounts come in short wide http://store.summitracing.com/partde...utoview=sku%20 and tall narrow http://store.summitracing.com/partde...utoview=sku%20 - both should fit on the subframe, but the tall narrow locate the engine higher in the engine bay by about 1/2" or so. I'm going to be using the tall narrow's for my installation.
For the plates - there are plates that have the lower front bolt on the plate also serve as the bolt for the lower mounting hole of the motor mount http://store.summitracing.com/largei...trd-4572_w.jpg; and there are plates that have a separate set of three holes for the motor mount http://store.summitracing.com/largei...12611hkr_w.jpg (note the Hooker plates also seem to raise the engine slightly), which locate the engine about an 1" or so back from the first kind of plate. I'm going to try the 1" to the rear plates, but may have firewall interference issues with my headers.
Take a look at the links and you should be able to see what I'm talking about. You're probably going to have to take the plunge and get plates and mounts and mock it up, unless someone with a Wayne Due frame steps up.
