Old 10-13-2005, 07:09 PM
Nutsy Nutsy is offline
Do you have a booth at SEMA? IF so where is it at? I am very interested in the boost ready LS2's!
Trev
Old 10-14-2005, 10:01 AM
Kevin@w2w Kevin@w2w is offline
We will be displaying at Sema
Old 10-20-2005, 05:32 AM
chuntington chuntington is offline
any progress?????? picks???
Chris.
Old 10-20-2005, 07:22 AM
Boost ready not done yet
Old 10-25-2005, 05:08 AM
looking good!
so how come you're not going for injection??
Chris.
Old 10-25-2005, 08:16 AM
Originally Posted by chuntington
looking good!
Chris.
That is just one of our crate engines
We will offer some injected models as well as a few other options.
The carb model isn't too bad considering it made 550 and from carb to oil pan weighs in at 345 lbs.
Old 10-25-2005, 08:49 AM
trapin's Avatar
trapin trapin is offline
Kevin....are these engine packages going to be available to view and research on your website following SEMA? If so....will there be pricing available such as there is for the Edelbrock engines? Or is it going to depend on the build? It would be nice to see a few engines on there that are advertised as already assembled and priced out-the-door.
Tony Rapin
The Pigeon Forge Project
A 1968 Pro-Touring LS1 Camaro.........and why not?
Old 10-25-2005, 09:31 AM
All information will be available like the others. Engines will be broken in on our dyno and also in different levels right down to the rotating assembly.
Parts used have been tested on our dynos just like all the other parts we use.
We even hired in a new engine builder and set up a special area just for the crate engine program
We still do specific application builds depending on performance goals.
All information will be available next week once I get the ok to put it on the site.
Old 10-25-2005, 11:10 AM
Damn True's Avatar
Damn True Damn True is offline
550, N/A, with a carb! Ok, you have my attention.
What is the compression ratio on that thing, and how much vacuum does it pull?
Old 10-26-2005, 05:19 AM
Hmmmmmmm, just imagine it with a set of throttle bodies on there!!!
or a pair of superchargers! opps, soory thats what you guys are going to be doing hehehe!
chris.
