Old 06-29-2009, 05:31 AM
SickSpeedMonte's Avatar
SickSpeedMonte SickSpeedMonte is offline
Originally Posted by CadVetteStang View Post
Nice ride. That was crazy with the old lady. What is the weight of the car? I’ve been thinking about doing a stock 500 Caddy powered 86 Cutlass, but I like your body style better. I would be autocrossing too- what diameter bars do you use and are they stock? My engine would add 35 pounds up front and I would want stiffer springs and shocks to corner flatter. I’d also need to put in a Ford 9” rear with 2.43 or 2.73 highway gears because of the torque. Since you have autocrossed yours, what changes would you make if your engine made 550 lbs. torque @ 3400 RPMs and added 35 lbs. up front? Do you have room for wider wheels under the fender if you increase the positive offset?
The car weighs 3740 lb with 3/4 tank of fuel and me in it. It's got a fiberglass hood and no A/C. 55/45 F/R weight distribution. It's nice having a platform scale at work
My bars are both stock. From the times I went autocrossing, I would have said that I was in serious need of more front roll stiffness, but after changing to the currie arms in the rear, things have changed. I seriously suspect that my stock suspension was in a good bit of bind at this low ride height. The Johnny Joints seem to have freed up the suspension articulation quite a bit. I've noticed some roll steer and the car just feels different (less stable actually). I wonder if I need to get the currie lower arms now, as the stockers have 200k on them and the bushings.
With 550 ft-lbs and an extra 35lb up front, over stock, you'll definately need stiffer springs. Then you will have to do some racing and testing to determine what to do with your bars, as the stiff front springs will add roll stiffness and may balance out the car.
I would also try to fit the fattest tires up front that you can, which on the SS is a 275/40/17 on a 9" wheel. I'm not sure on the offset, as I have never run wider than an 8" wheel.
Personally, I don't have much room for a wider tire, front or rear. The car is too low in the front (it tucks tire) and the rear tire is as wide as it gets without rubbing the frame or sticking out past the wheel arch.
Old 06-29-2009, 10:59 AM
CadVetteStang's Avatar
CadVetteStang CadVetteStang is offline
When you lowered the front of the car (speaking only of the amount that may have been lowered by the springs), did you shorten the sway bar end links to level the sway bar? Assuming you have the standard front bushings and side end links that are essentially extra long bolts that run through a metal sleeve that separates the end link bushings- you would have to cut the sleeves down so that the sides of the bar are level again. This may require shorter grade 8 bolts if the ones you have are not threaded all the way through. If you did not cut the sleeves- and if the springs lowered the car much, then the swaybar is in a bind. If you switch to polyurethane bushings and end links, be sure to leave some room for the end links to work- if you tighten the end link bolts too much, the bar can only work by bending the bolts. – that can make it bind too--- until the bolt breaks.
Unstable? An often overlooked adjustment when lowering and or changing the forward rake or stance of the car is the front end alignment. You have had so much done to yours that a factory spec alignment may no longer be correctly angled- especially in camber and caster. You might need someone (who knows more than me) to figure out what the best alignment angles would be for you.
Here are three sites that talk about alignments; the last one is for Regals and should be more specific to your car:
http://www.familycar.com/Alignment.htm
Also: http://www.tirerack.com/tires/tirete...e.jsp?techid=4
And: http://www.gnttype.org/techarea/susp...uspension.html
The Cadinator: 82 Eldorado, Caddy 472 (535 Lbs. Torque @ 3000 RPM) Autocross suspension, 95 Trans Am wheels.
Battlecar Cadillactica: 70 Eldorado w/stock Caddy 500(550 lbs. torque @ 3200 RPM) Known for beating Trans Ams, Camaros & Mustangs in 1985/86 Fayetteville Arkansas SCCA autocross
CadVetteStang: 72 Fastback Mustang w/500 Caddy engine, TH400, 12” disc brakes & 9” rear end. Was in storage awaiting a C4 Corvette front suspension when sold by [former] friend.
Old 06-30-2009, 08:41 AM
montessaj montessaj is offline
Bernie, I'm glad you took my advice and got on this site! Lots of excellent cars on this site, and its the perfect place for your Monte.
Andy
Old 07-01-2009, 05:28 AM
I didn't shorten the end links, and thank you for pointing that out. The springs lowered the car about 2", so judginb by the end link location, in relation to the LBJ and LCA bushings, the end links probably need to be 1.25" shorter or so. Thanks for the tip.
I do plan on getting an alignment done, but I need to get a new steering box first. The one in the car is the original and has 200k+ on it.
Andy
Thanks for the referral! I'm loving it here.
Old 07-31-2009, 07:13 AM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
Very neat car. I really like the Monte SS of that year.
Jim
