View Poll Results: What engine will you be using?
SBC w/ EFI 42 7.00%
SBC w/carb 98 16.33%
BBC w/ EFI 41 6.83%
BBC w/ carb 50 8.33%
LSx 204 34.00%
LSx w/ forced induction 80 13.33%
Other 70 11.67%
SBC w/ EFI & Forced Induction 15 2.50%
Voters: 600. You may not vote on this poll
Old 05-27-2009, 05:40 AM
almcbri's Avatar
almcbri almcbri is offline
Update:
stock LS1 w/ Texas speed and performance cam kit 228R, headers, tune, cold air intake, ported throttle body, LS6 intake ect.
1968 Camaro LS1/T56, Hotchkis Springs, Tubular Arms, AFCO sway bar, C5 brakes, VWW 18" V40's http://s14.photobucket.com/albums/a3...1968%20Camaro/
Old 05-27-2009, 07:27 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Originally Posted by 70rs View Post
I made my choice today. BBC w/carb. 454 at this point but I will have to go through it. Not sure where it will end up for displacement yet. EFI and forced induction to come later as the budget allows.
Sounds like a good choice.
I'm a fan of those BBC's myself.
Old 05-27-2009, 10:57 PM
70rs's Avatar
70rs 70rs is offline
Tones2ss, This will be my first big block. I'm kind of looking for ideas on how to set it up. Looking for 450+hp and 450+tq. It will be street driven but not a daily driver. I'll have a manual trans behind it. And it will be abused on a regular basis by my right foot.
So which heads? Intake? Cam?
It is a stock mid 70's 454 out of a 3/4 ton truck.
It runs good now but has about 100k on it so I will tear it down and do a full rebuild.
I am planning to use the stock crank and rods as long as they check out ok.
(unless there is a cost efficient way to stroke it?)
Thanks for any ideas/tips,
Eric
Old 05-28-2009, 01:50 PM
tones2SS's Avatar
Thumbs up
Eric
No offense, but you're asking the wrong guy. I'm looking for ideas and suggestions myself.
Seems like we both have almost the same type of build in mind, except that I'll be doing a '69 Camaro and maybe fuel injected? Not sure yet if I want to do a carb or fuel injected???
Good luck with everything!
Old 06-23-2009, 02:02 PM
Ravenous70's Avatar
Ravenous70 Ravenous70 is offline
Stg 2 LS6 headed LS1 with Victor jr Carb Intake
70'Camaro-Teal,Black Cloth,Cowl Hood, T/A spoiler,LS1+N2O, LS6 Stg2 heads, Futral Custom Cam, Victor Jr, etc, etc Up and Running!!!, Built TH350http://www.cardomain.com/ride/3069774
06 GSXR 750
Frum Roll Racing
Old 06-26-2009, 09:09 AM
holschen's Avatar
holschen holschen is offline
Default l76
guess i buy a L76 with headers and use a 6l80e
g8 engine
tired of lt1
and big block is to much as i want aluminum block
camaro69-l92+6l80e-
speedtech(LCA)-ats Street-Comp AFX-unisteer r&p-VariShock
camaro 5gen rear
Hydratech Brake Booster
movit brakes 380mm 6piston front- brembo 465mm 4piston rear
275/30-19 front-325/25-20 rear
19x9f 20x12r cray scorpions
Old 07-07-2009, 05:00 PM
Wrecked Em's Avatar
Wrecked Em Wrecked Em is offline
462 ci EFI Big Block Buick
Old 07-08-2009, 02:34 PM
Originally Posted by manny z View Post
I going to use a big block 383 .030 steel crank, worked stock rods, all ARP hardware, EDELBROCK ALUM HEADS, RPM INTAKE, 528 LIFT, 284 DUR CAM, ROLLER ROCKERS, 10 DEG RET AND LOCKS, kEITH BLACK EXT OILING SYSTEM, CUSTOM MADE SHALLOW 10 QUART PAN, DEMON CARD, PRO-CHARGER D1SC SUPER CHARGER, CUTOM INTERCOOLER, CUSTOM MADE SEMI SHORTY HEADERS.
What the hell is a big block 383??
Old 07-08-2009, 02:39 PM
70rs's Avatar
Wrecked em--- That Buick motor is going to rock! Torque monster!
Old 07-09-2009, 06:14 AM
h_leadfoot h_leadfoot is offline
LS3 making 490 rwhp with T56 tranny..
