Old 07-16-2009, 11:49 PM
1stGenSS's Avatar
1stGenSS 1stGenSS is offline
Default Z06 wheels
I am looking at getting some Z06 wheels for my 1969 camaro.... What is the biggest width you can go on a stock subframe? also what is the largest width I can go with no Tubs in the rear...?
Old 07-17-2009, 12:20 AM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
No aftermarket subframe and no mini-tub = no ZO6 wheels for you.
Old 07-17-2009, 12:40 AM
Apogee Apogee is offline
The C5 and C6 Z06 wheels are different diameters, widths and offsets between the two applications, as well as similar but different 10-spoke designs. If you just want that style of wheel, you can get reproduction versions in various different sizes and finishes, however all will be of a high-offset design and require wheel adapters to make up for the offset/backspacing.
In general, an 8" wide wheel up front and 9.5" in the back with 245/275 rubber front/rear will fit without too much difficulty...seems to be one of the most common fitments. If you're really careful and somewhat lucky, you might be able to go 1/2" wider on the wheels, but BS becomes uber-critical and rubbing much more likely everywhere depending on your ride height and tire diameter. Overall tolerances on the car with respect to the rear axle being centered relative to the quarters and rear sub start to become more and more critical the bigger you go.
That said, there are ways to fit bigger wheels/tires up front if you don't mind sacrificing some turning radius. A quick search will turn up a bunch of reading for you.
Tobin
KORE3
www.kore3.com
