Old 10-26-2005, 08:40 AM
darren@ridetech's Avatar
darren@ridetech darren@ridetech is offline
Originally Posted by Johnny Blaze
Of the bolt in style, which would be best? I am building a vert, and am affraid to cut up the body, and have problems with the structural integrety.
The AirBar does not require any mods to the floor pan. The only welding will be the upper bar tabs to the axle tube. Up front you will have to do a little trimming on the outside of the coil spring pocket. This will not reduce the structural integrity of the front end though.
As far a geometry goes it has a good instant center; close to the crank.
DSE's setup will work with Shockwaves. I'm not sure about Mean69's setup though.
