Go Back   Lateral-g Forums > Classifieds > Wanted/WTB
Old 08-04-2009, 12:09 PM
clay69camaro's Avatar
clay69camaro clay69camaro is offline
Default Dart little M short block
I looking to see if anyone has one of these blocks in new or like new condition with the crank rods and pistons already installed. Maybe you went another direction with your build and all that.
Old 08-04-2009, 12:23 PM
Try racing Junk.com. You will likly strike out as most people that invest in these blocks dont sell them at all and if they do not cheap. DART sells a short block using thier SHP block which is good to 600 Per Datrt but most say 800. They are pretty reasonable too.
Old 11-22-2009, 06:26 PM
VetteCam VetteCam is offline
Clay,
I sent you a couple more emails in regards to my Dart Lil M long block.
Take care,
Donnie
Old 11-22-2009, 09:09 PM
Cris@JCG's Avatar
Cris@JCG Cris@JCG is offline
I got one off these!
Dart Little M Block- 406 ci
Lunati Rotating assembly internally balanced
ATI Dampner
Crane roller with .900 base circle, roller lifter, rockers
Dart CNC heads
Also got a 555 Big Block with Dart Big M block
Machine work by Kenny Duttweiler
Old 01-18-2010, 10:51 AM
Harri-76 Harri-76 is offline
Got my SHP block and itīs really sweet. The whole construction is made power in mind... To see this block makes you to belive that its good for mor than 600 hp. Well at least it will be enough for me at this stage, when Iīm aiming at 550 hp at flywheel.
