Old 08-04-2009, 03:47 PM
Steve1968LS2's Avatar
I can sell you a regular T56 (f-body style) for a $1000 if you really want to save money.. just don't launch TOO hard with that big block. lol
Old 08-04-2009, 03:53 PM
rogue rogue is offline
I think I'd blow it up within a week but thanks
Old 08-04-2009, 04:14 PM
No power steering! If you decide to go with the magnum which is the new mac daddy on the block, then the next questions is: Do you need to cut your floor and will your shifter position change?
Old 08-04-2009, 07:55 PM
Yup. You should see me after a few sessions at a track event. My arms are dead tired and I look like I've been hit by a 18 wheeler. A hydraulic clutch would be nice as well.
Its my understanding they use the Hurst Blackjack magnum offset shifter to fit the stock console...
http://www.classicchevy5speed.com/De...T56Magnum.aspx
High performance Hurst Blackjack Magnum offset shifter built with 4340 heat treated billet steel & 6061, T-6 aircraft quality billet aluminum, and a Delrin pivot ball, this direct bolt-on replacement shifter achieves perfect shift stick positioning within your stock console without modifications to your console or to the transmission. Go with the best - go with Hurst!
Exclusively available from Classic Motorsports Group. Add $295
The more time I spend building this car, the more I think I should just drop it off with a big fat check and my goals to a builder so its done right...
Old 08-04-2009, 07:57 PM
Yea, the shifter should be out soon and will allow easier positioning of the shifter handle.
To be honest from a functional standpoint the shifter that comes with the trans is pretty damn nice.
And yea.. this can be an expensive damn hobby..
Old 08-04-2009, 07:58 PM
Well I'm getting to the point where the car is well sorted for a shade tree mechanic build and performs quite well. But I'd like to take it to Bob Owens/Big Red status. Race prepped monster.
Old 08-04-2009, 08:57 PM
I'm running R888's on the street now. Gots to have me some traction. My spare wheels are stacked neatly. If I decided to go on a long run, I'll swap them. If you can interchange parts from the magnum and the regular t56 that could be a good option until you grenade it. What about upgrading Steve's? I don't know much about the T56.
Old 08-04-2009, 06:36 PM
Just don't launch on slicks and you'll be fine.. hard hits are what kills these things.
Seriously.. the Magnum is a far superior trans in terms of technology. If you can afford it then you won't be dissapointed.
Yeah no drag racing for me. Though I do launch pretty hard on R-comps frequently. I've already burned through a set of RA1s and am due for some new rubber already.
What are you and Todd running on your street wheels, or are they garage ornaments for now? I'm thinking I might run some street tires for a while to help me learn even further at the track. The r-comps are cheating.
