Old 08-12-2009, 03:12 PM
pro-touring.no's Avatar
pro-touring.no pro-touring.no is offline
Default Ls1.. howe to get more power..
Hi.. I Will use carburetor on my ls1 with auto/trans and I will try to get 500 hors out of it.. Is that possible.. without using to many$$ any one who has any tips to me
Old 08-12-2009, 04:09 PM
500 flywheel or 500 rear wheel HP? 500 flywheel will likely take a head and cam swap, 500 rwhp will require even more mods, or a power adder such as a blower, nitrous, etc.
This is doable, but I'd figure heads and cam at $2500+, plus of course a proper tune, headers with a good exhaust, etc. You can pick up good power with just a cam swap, headers, and tune, but not going to reach 500 HP with an LS1 without a head swap or fully ported heads at least in addition to the headers and cam.
Old 08-12-2009, 11:58 PM
It will be 500 hors on the flywheel.... what type of carburater and manifold??
thanks
Old 08-13-2009, 07:02 AM
thanks
I would keep it efi, no carb. But if you go carb there are only a few choices for an intake; GM Performance has one, and I believe Edelbrock also does, and that's about all I've heard of. Since they're a fuel injected engine there's not a lot of intake manifolds out there for carbs.
On the carb, probably something in the 750 cfm range or so.
Old 08-13-2009, 09:02 AM
Lateral-g Moderator
Damn Jody your good.
Old 08-13-2009, 03:25 PM
70rs's Avatar
70rs 70rs is offline
I thought I read somewhere Trick Flow had an LS manifold. ?? I think the choices are slim but getting better.
Old 08-13-2009, 04:00 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
FAST makes an intake as well. Not sure how well they stack up against the ones Jody listed here. (Jody knows his stuff!!)
Old 08-17-2009, 12:10 AM
can i use AFR 225 on Ls1 ore are they to big??
kjell
